TomC750
I am fastening 2x4s flat against cinderblock wall with 1" XPS between 2x's and wall. I started to use 1/4 "by 4" Tapcons so I would have sufficient length into the block. However, most would strip out. I had used a 3/16 masonry drill. I then went to a 5/32 drill and my impact driver would stall out before the Tapcon was all the way in. I decided to use 3 1/2 " cut masonry nails, sometimes they did not hold. Years ago I used spring nails into a concrete wall with good results. If I had any left I would try that, but can't find a source for them now. My blocks are very dense, so I don't think that is a factor. Thoughts anyone?
![types-of-masonry-and-concrete-anchors-2022-section-2[1].jpg types-of-masonry-and-concrete-anchors-2022-section-2[1].jpg](https://www.garagejournal.com/forum/data/attachments/1660/1660592-b4b1a5c1f92527dcad82effbaf106e93.jpg)
