Square D Qwik Grip work around?
DanielVetpath
Hi Folks:
I bought a new subpanel for the electrician to install in my shop. Asked the local electrical supply store for a Square D panel, main lug and didn't think twice about it. I left it at the shop for the electrician to install. My plan was to take most of the circuits out of the top of the panel using 3/4 emt. I stopped by to see the panel in place and found Square D's Qwik Grip plastic inserts for wire management taking up most of the real estate. I didn't know this was an option or even existed. Amateur mistake. Any suggestions for working around this? I am pretty sure what I see is what I get. I can use the knock outs on the side and bottom, but it adds an extra bend and complicates the process. Just wanted to see if anyone else has dealt with this. Drilling holes in those plastic inserts for emt connectors seems tempting, but cringe at the same time. Considering bringing a 1 1/2" or 2" elbow out of the side and feeding a wire way box above the subpanel. This is a block building with steel bar joists so bending and running conduit is a bit tricky with lights already in place. Thanks for any input. Daniel
yatg
Southern Oregon
How about popping the plastic out, bolt 2 or 3 gang blank plates over the holes, and make your own holes in the plates. Will take some measuring and cutting/trimming to preserve the existing factory KOs. Use a KO punch and prepunch before fastening to panel. Use KO plugs for any unused holes for future work.
D
DanielVetpath
I was tempted to do that but didn't know if it was an acceptable practice.
D
DanielVetpath
Thanks for all of the input. My local electrical supply will have another subpanel for me in the am. In the long run, I won't remember the extra 80$ I had to spend, only that it looks and works like I wanted. I will chalk this one up to experience! Thanks again everyone for weighing in. I think If it came down to it, I would do the plate patch. Still reacting to all of the mess that was in this building when I bought it. Can't stand the thought of someone coming behind me and complaining about my work. Take care, Daniel
alfredeneuman
Fullerton, CA
Not exactly the same situation, but close. I've screwed 4X4 blank plates to the tops of panels where the knockouts were torn up and punched my holes in the blanks. .
4X4 covers extend beyond the depth of a standard panel. Cut them off with a bandsaw, sawzall, or heaven forbid hacksaw (They need to be cut from both sides because the plate is wider than the throat of the hacksaw)
sparky 1971
Central Iowa
It was a panelboard that some jackwad that wasn't me installed with the factory knockouts on top. I always put the ko's down so there are no knockouts on top. I'll punch my own holes where I want them.
If it were a loadcenter I think I'd break out my M12 cut off tool and if I didn't have one, it would be a good reason to buy one. :thumbup:
ArcReactorKC
Out in the county NE of KCMO
I always quote no knockout panels to EC's very very rarely do I have anybody ask for a pre-ko panel.
