How do you make this bend?
CUSTOMMANCAVES.COM
Toms River, NJ
I am trying to reproduce this piece. It is a rear shelf for a race car that fits over the space where the rear seat used to be. It is a little over 3' wide. The first pic is a side shot of the bend in question. The second pic is looking at the piece from underneath.
So, my question is, how do you create this bend across a single 38" piece of sheet aluminum? Will a regular brake work? Box brake? Or is some sort of press used? :headscrat :confused:
nate379
Palmer, AK
Yup. A steel yard that does cutting, bending, etc (many do) will. It is something that you need in order to bend metal over light sheet metal thickness. I have seen then large enough that they could bend full sheets of 1/2" plate :thumbup:
GeorgiaHybrid
Extreme NW Georgia
Any misc. or structural fab shop will have what you need. They use them all the time to bend pans for stairs. The larger presses can do thicker plate but they all limit the radius of the bend to 2X the plate thickness for anything much over 1/8.
GeorgiaHybrid
Extreme NW Georgia
MadMechMaster
Frankfort, IL
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
If I had to do that quickly at home, I'd make it out of two parts, welded together at the tight bend. It's nowhere near as quick as the appropriate brake die, but it would be the fastest way without one. Actually, looking at it again ... I'd extend the metal at that point another quarter inch, punch a series of holes in one side and just plug weld it .... or if you've got access to a spot welder use that. Far faster than trying to weld the entire length of the seam.
larry_g
oregon
Do you really need that particular bend? Why is it there? Is the lip going up needed for function or just stiffining the bend up? Could you imagine making a simple bend and then adding a stiffiner by bolting/riveting/welding?
lg
no neat sig line
C
CUSTOMMANCAVES.COM
Toms River, NJ
It serves two purposes: A stiffener and it keeps objects from sliding off the rear package tray. It is also aesthetic.
Yes, I could probably re-design, but my goal is to reverse-engineer and stamp these out to sell. Welding would take more time and add to the cost.
chopperman1
If you are planning on selling them then I you will need a correct die for the press to get consistent results quickly and efficiently.
C
CUSTOMMANCAVES.COM
Toms River, NJ
Yes, I plan on making a pattern and bringing the pieces, ready to bend, to a local fab shop. I'll have them make the bend then I'll finish trimming, etc. Eventually, if these sell, I'll have to purchase my own equipment.
gorilla
That piece is more difficult than it seems at first glance. The 90* edge bends will be done first, then the 90* bend with a bottom die that will allow the edges to hang over the ends. then the acute bend with a knife die that will fit inside the edges. You will pay a lot of $ for this because of the set- up required. The cost per unit will go down a bunch if you have more made. Try to find a shop that builds chassis for electronics equipment this work is easy for them shops that do structural steel will not have the correct tooling.
rsanter
visalia ca
a box and pan brake will do it
you will make the 90 degree bend first and then the other one
bob
gorilla
IMHO if you want to make just one you could do in a box and pan break but it would take a lot of mickey mousing around, more than one a press break would be better.
welderwink
Pa
That piece looks pretty complicated from the pics you posted. A shop might want nothing to do with it if your just making one piece, it could take a lot of time and messing around to get it, and thats if you have the right dies. If you had a order of a few hundred that would be one thing.
C
CUSTOMMANCAVES.COM
Toms River, NJ
Is it really that complicated? Looking over the entire piece, it appears to be very "home-made". My goal is to make a couple of better/heavier quality and see if/how they sell. If they are well received by my target market, then I'll go into full production.
speed bump
Butte Montana
If I was making them for profit and directly ripping off that design I would probably just make a die and a hydraulic press to bang the shape out in one operation.
If I was doing it to look spiffy I would bead roll the top for the lip and then bend it in a normal brake.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
That kind of bend is done on a Press Brake.
Check this on how the Press Brake works. http://en.wikipedia.org/wiki/Press_brake
Quite a few metal fabricating shops that work in sheetmetal have them. You can also check with your local heating contractors that make up their own ductwork to see if they use them at their shop. Some will bend metal for a minimum charge.
