nissan_crawler
Soon to come, FH872 and SH872.
Pay no attention to the furry feet...
Why snap on make more different round ratchets??
is your cats 5 toes?? my parents have 2 6-toes cats... one is pretty white and other one is mixture of white, black, and gray... i love both cats...
Like that's gonna be possible....Are they holding the backlight for you for cleaner shots? Better training on your camera assistants will result in less post-production work for your editor you know.
I know you just did it, so you won't have an answer, but I wonder how do those handles hold up to chemicals and oil. I have a pair of diaginal cutter that found an accidental oil bath once years ago and the stupid hangle grips still twist on me depite removal and cleaning. I would be a bit concerned about the twist potential on the handle - especially on the 1/2" size.
Care to share the modification info, part #'s and process of doing this; on your ratchets? I'm assuming that you drilled out the handles a bit to get them to fit a "normal" handle... inquiring minds want to know!![]()
The first thing I notice is that it looks proportional. On the mods I've seen before, the handle just looks way too big for the 1/4 ratchet.
Was it a small pick handle?
Do you drill a plain hole, or put tangs also?
It's a standard ratchet handle, I didn't do anything to the handle. I turned the ratchet down on my belt sander, ran a weld bead on each side, filed them into tangs, then beat the handle on.
1/4" green soft grip = th936-12g $4.90
3/8" green soft grip = fh936-12g $6.25
1/2" green soft grip = sh936-12g $7.85
As for the cats...
Can I use one of these green softgrip handles to replace the red handle (that is smashed) on my 1/4 rotohead ratchet? This is the handle currently on it
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=120345004749
-Dan
I'm thinking long a similar line: Would the 3/8" grip fit the current FHOF80?
She had the 3/8" handle, 1/2" should be in next week.I'm thinking long a similar line: Would the 3/8" grip fit the current FHOF80?
Yep, I want green to match the screwdrivers.
Do you think you could take a 17" SF80 and cut it down a bit and put a comfort grip. . . making it about 13" long ?
We need more pictures of the cat's >.>
well maybe some more of nissan's little shop and work area as well.
As for the cats...
Are you still selling these?
I never was...
