I had to drill a 1.5" hole thru high dollar marble to mount a steam shower controller. Hole had to be in a precise location. Hole saw had no pilot as shown below.
I put blue tape on the marble and carefully marked the needed centerline with large cross-hairs both vertically and horizontally.
I then took a 2x4 and thru drilled it with a 1.5" hole saw and marked the hole centers on the face and sides of the 2x4 prior to drilling. I then put two-sided tape on the 2x4 and pressed it tight to the marble aligning my marks; this centered the bored hole on the centerline of the hole to be cut. The 2x4 then served as the pilot for the pilot-less hole saw.
Used a putty knife to pry off the 2x4. For the record, the Gorilla Glue 2-sided tape is damn strong!
