I ordered the Tsunoda pliers, they weren't much that that piece but they're so nice at what they're designed to do, and as a bonus also great for removing small E-clips (actually use them more for than than for chain links now).Chain master link tool https://www.mcmaster.com/2372k1/
lol ordered
How do you like the hole saw slug removers?McMaster Carr has gotten me a couple times.
Hole saw slug remover https://www.mcmaster.com/4067A22/
Sock it outs for removing stripped allens https://www.mcmaster.com/2643A52/
I'm tempted......Saw it and had to buy it. The Cresent nail puller.
Do they work on little hole saws like 7/8”? I use mostly 7/8”, 1 1/8”, and 1 3/8”.
I wasn't going to click on this thread but then I decided to and it just cost me $28
You need a slide hammer puller: https://www.amazon.com/dp/B00002N7SD/?tag=atomicindus08-20Clealy we all have differnt work flow and tools we like. I added this to the mix and allong with a cats paw, wonder bar or flat bar, a couple wrecking bars, a straight claw and curved claw hammer I believe I am well armed to tackle the job of nail removal. This was an internet find. I am happy I picked it up.
I posted them before, but:
Klein romex cable strippers. I never knew such a thing existed, and I went to school for Electricity (albeit a thousand years ago), lol. I have always just used a utility knife to strip the jacket. Somebody posted about these, and I figured I'd order them and give them a try. I have used them once already, and it's like a strange forbidden shortcut. It feels weird, lol.
I keep talking myself out of buying one, because I don't really need it, but I feel like if there's a zombie a apocalypse, this is the tool to have.I actually have bought one of these... in no small part because it's called FuBAR:
FuBar | STANLEY® Tools
www.stanleytools.com
I bought one to take apart a pergola. It made it quick and easy. Just nice controlled motions taking everything apart. No swinging or noise. Fubar for the win.I keep talking myself out of buying one, because I don't really need it, but I feel like if there's a zombie a apocalypse, this is the tool to have.
Get stuck in a room, just make your own door. Pointy end for dispatching zombies, hammer end for making sure. No fuel or ammo required.
A couple I've come across:
Gedore E-8730 - deburrer to fit a 1/4" bit handle
https://www.kctool.com/gedore-e-8730-deburrer-bit-1-4-hex/
Trusco TTX-92 - Long stubby hex key set with a 90 degree offset bend on the opposite end to offer an "in between" position for working with socket heads in tight quarters where a bit ratchet might not fit
Seems like it, same country of origin. Looked a little more and Home Depot has a 4 pack for close the McMaster-Carr price. Looks like the OEM is Shaviv/Vargus.Are these the same ones? https://www.mcmaster.com/7811A18/
It already cost me $28I am never going to financially recover from reading this thread....
DaveW
I've owned a set of GW ratcheting box wrenches for over 20 years, and - when I saw these - I was like "Dang, now that's a cool idea". Snapped them up, use them alot. Even on jobs that aren't tight areas. Using a socket with a GW just works!
Quick release, with knurl ring, compact size, takes a wrench you have and makes it a fine tooth close quarters ratchet.
GearWrench 9230D 3-Piece Metric Gear Wrench Drive Adapter Set | ToolDiscounter
9230D 3-Piece Metric Gear Wrench Drive Adapter Set. Shop Specialty Wrench from GearWrench at ToolDiscounterwww.tooldiscounter.com
Koken offers them as well, still spendy but a bit cheaper than snappy. Also depending on what sizes you need schley and lisle offer 17, 19, 21, and 22. I use the schleys for high pressure lines on diesels.These are stupid money, and have a pretty limited utility (hydraulic line fittings, maybe some sensors), but I definitely plan to buy one or two (sockets, not sets) soon.
Snap-on Store
shop.snapon.com
Another GJ user pointed these out to me in the crowfoot thread. Lots more fun stuff over there.
Help me pick a Crowfoot Wrench Set
I'm in the market for a crowfoot wrench set. I can't decide between a standard open end set or a flare nut end set. Which would you buy? Which do you own/use? Why? Please refrain from just saying "buy both". I don't want both. I want one set that's going to work ~90% of the time. These will be...www.garagejournal.com
Mike
