600SL
I'm interested in a product called Crete-Heat insulation, see the link. It looks to be pretty good. But I'm trying to figure out a way of suspending rebar over it. Looks like standard chairs will just fall over. I have seen very few pictures where people are just placing the rebar on top of the mat. but that doesn't seem appropriate for a 6" concrete. Am I correct in thinking the rebar should be at the center of the concrete. Therefore I would need to suspend the rebar ~1.5" above the high spots on the Crete-Heat or 2.5" about the low spots. The attached picture is the only one I can find with rebar installed. The installation will be on a 28' x 16' garage floor located in CT. Any advice would be appreciated.
crete-heat.com
Crete-Heat, LLC | Floor Panel System | Grade Installations
Crete-Heat, LLC insulated floor panel system is an easily assembled modular board, insulation, vapor barrier (10-mil polystyrene film), and radiant floor tube holding grid that allows for simplified installation of hydronic radiant floor heating systems. Contact us for a floor panel system.
