Shocker
Olympia, WA
V
vwpieces
Hills, PA
hope someone can use those 51348. The MP means Max Pack or by the case...
I checked the cross ref numbers and nothing I have can use them.
Schirmer
$46.41 (2) 6 TON JACK STANDS (12K#)​
TCE 6 Ton (12,000 LBs) Capacity Double Locking Steel Jack Stands, 2 Pack, Blue, AT46002AU​
$46.41, seems to be a fair price for a pair of 6 ton, each, stands. Unknown quality, I'm sure it's similar in quality to its many competitors stands.
Wyoming09
Wyoming, MI
A link would be helpful.
tabs
wv
non tool but here are some tshirts for pretty cheap. just bought two 10-packs for under $15 each. some colors and most sizes are listed for like 60-70% off. had them on my watch list while waiting for a refund for another item to hit my amazon gift card. be aware it's a 3rd party seller/shipper soooo probably one of those algo mislistings where they'll send you less than the 10-pack, but i've always been able to get a refund and usually get to keep the item so we'll see.
Gildan Men's Heavy Cotton T-Shirt, Style G5000, Multipack​
pbon
Just worked for me. Thanks! Those look cute. And every now and then you need a tiny wrench.
bubinga
Shocker
Olympia, WA
So is Cr-V good or bad for impact sockets?
So this debate has been going on for years. Cr-Mo is more ductile and softer. It will deform before cracking. Cr-V is harder and will crack quicker.
Cr-Mo also will mushroom out and make the socket useless wheras Cr-V will hold it's shape.
Bottom line is that either type should be just fine. I have never cracked or broken a Cr-V impact socket. I have also never had a Cr-Mo socket deform to the point of uselessness.
Currently I have almost all Cr-V impacts in 1/4", 3/8" and 1/2". I just picked up some 3/4" drive Cr-Mo units for when I get a bus. :)
tabs
wv
FYI those ignition wrenches can also make interesting/cool keychains. just get the actual key ring and thread through the closed end and you've got a tool themed keyring! i put all my cabinet/tool box keys on them then stuck a dime-sized button magnet on the side of the box and put the wrench on it so i've always got it on hand but never in the way. keep the 2nd sets on a 3/4 wrench in the house as a spare.
