Making an ‘old work’ ice maker box
DGersic
DeKalb, IL
I need an in-wall ice maker valve box. Everything on the market is intended for new construction, pre sheetrock, and is stud mounted. I need something like an “old work” electrical box that I can cut in where I need it to go, without having to cut all the way to the studs and fix the resulting mess of sheetrock.
I’ve found several other web forum postings with people looking for this, so it’s not a new original idea, but there aren’t any answers out there. Hopefully the next guy searching for it finds this thread.
I started with this in-wall box with valve and anti hammer.
B3684D88-48FE-4C30-8CC5-CDD923E7D3DA.jpegE5EDA2F7-1A26-4303-8E46-E5A6C0815FC5.jpeg5F9425EC-0849-4E9C-983E-94FC83DADCAC.jpeg7636D763-EE17-4983-A4B0-1B65D6016CC8.jpeg
D
DGersic
DeKalb, IL
I cut the top and bottom off a cheap old work box from Menards.
My first thought was to put the old work mechanism where the mounting tabs are on the box. It could be done, but the front face plate isn’t quite big enough to cover them this way.
Trimming down the tabs to fit behind the face plate would work, if you’re so inclined.
PoorUB
Fargo, ND
If it were me, I would use the box you pictured, cut off the four ears, cut a hole just big enough to slip inplace. Connect the PEX and caulk it on the backside of the flange and shove it into the hole. Block something against it for a day until the caulk dries .
D
DGersic
DeKalb, IL
Instead of the sides, the top and bottom have a bit more clearance. Just enough.
I cut out a valve mounting hole with a 1” hole saw. That’s slightly too big, but I don’t have a 7/8” hole saw. Clearance for the valve mounting ring was done with a Dremel sanding drum,
Side ears removed.
D
DGersic
DeKalb, IL
Four 1/8” holes, four rivets, and the old work tabs are mounted to the box.
E5DBE24B-A003-47F4-A0AB-1F1E42A5D61F.jpeg8072E769-7215-429C-B144-721384C87623.jpeg46F215B9-418E-4A30-8675-89EEFFF67CD3.jpeg
Now to install it and finish off this part of the plumbing project.
D
DGersic
DeKalb, IL
What fun would that be?
If I had a 3D printer, I’d make the whole box. Nobody but me will ever see this, but it makes me happy.
In The Doghouse
South of Due West, West of NinetySix in SC
I need to remove the old ice-maker valve (the garden hose thread type with 1/2" copper pipe) and install a new 1/4" outlet valve routed from the crawlspace with Pex tubing. I'll have to cut & pry the old box out of there and deal with removing the copper pipe, then replace the box after running and crimping the Pex. But as @DGersic stated, there seems to be only the new construction boxes with tabs to fasten to the wall studs.
I see this as a viable option if a post-built wall-box isn't available. Does anyone have a better idea?
Fav Onefour
MN cold and hot
The box is pretty cool. I can see why there aren't options being made. It's generally pretty tough to flex and stuff plumbing.
I have dealt with dozens of those fridge water lines and I've yet to see one done with a box. Most of them have a shutoff valve at the main line connection with the 1/4" snaked up to the fridge. The main water line connections are usually done in basement ceilings. Not sure if that's a regional thing?
D
DGersic
DeKalb, IL
There are probably many ways to cut nnect the water to the fridge and route the line. Just so long as it’s nearly routed, it’s all good.
