Slotted screws in electric boxes
gba2331
After removing a dozen pendant lights, it finally hit me - why do the screws inside electric outlets and boxes use slotted heads instead of Philips? Slotted head screws are such a pain and it seems like Philips would work, or am I just dealing with older installations?
I can understand slotted heads for the covers but not for the excessively long screws that hold an outlet into the box.
Blue Chips
Maine
Older equipment may vary. I have some old steel junction boxes lying around that have straight-slot screws for box covers or for mounting box extensions, but most of the boxes, receptacles, and luminaires that I've installed in recent years have combination-head screws, usually in a pan-head profile. They look like a combination of a phillips and a straight-slot head.
I have a number of combo screwdrivers and bits made specifically for those screws. The screwdrivers are available in different sizes.
Here's an example of a screwdriver from Wiha:
https://www.wihatools.com/products/insulated-xeno-2-softfinishr-driver
And a variation from from Klein:
https://www.kleintools.com/catalog/screwdriver-sets/screwdriver-set-combination-tip-2-piece
Brochure from Klein:
https://data.kleintools.com/sites/a...rochures/klein/Combo-Tip-Sell-Sheet_96252.pdf
Receptacle covers still usually have straight-slot screws, probably for aesthetic reasons.
nadogail
Coronado, CA
All the wiring devices I have purchased in the last 30+ years have had Combo head screws on the terminals.
whateg01
doo dah, kansas, usa
You totally need to replace those screws with combination head screws and get the awesome tool that nobody can live without! Or is it everybody should live without? Damn I can't remember where it left off.
Big Bad Dad
Southwest/ Central Va.
I just helped my son remodel his newly bought house that was built in 1961. We replaced all the old worn out receptacles plus added in some new circuits with ground wires to supplement the existing 2 wire receptacles. Those old slot head screws were a pain. Especially in this house, since the plaster walls were 1" thick over the studs, so the screws were even longer than usual.
infinkc
Wonder if switch plates will ever go away from slotted screws. Least they make concealed screw less now.
David Paul
Western New Jersey
Thanks for the links. Ordered the Wiha. Another tool I didn’t realize I needed.
kbuhagiar
Escondido, CA
Doubt it.
Concealed plates are fine in a perfect world. In the real world most wall surfaces are not suitable for them.
The nylon mid-size plates are the best compromise available.
andyvh1959
Green Bay WI
I'm surprised switch/outlet covers still have screws at all. You think by now someone would have developed covers with flexible tabs so all you needed to do is push the cover "home" to install it. Cost savings, no more screws. The flexible tabs could have steps on them to allow for the box depth, wall/plaster thickness. Kind of like the lock tabs in zip ties.
alfredeneuman
Fullerton, CA
Screwless covers already are produced. The "screws" are soft enough to pull out the holes for the plate's removal.
