why are non ratcheting flex head box ends not a thing?
FSUwelder1212
It seems these days that the extra long flex head ratcheting box end wrenches (primarily manufactured by kabo) are all the rage and has me thinking that I would like to try a set. However, looking around I think that the fixed box end with flex ratcheting on the opposite end such as the matco SRFBZLM102TA set or gearwrench 120 xp 86126 set would be more useful due to the fixed box end being able to break the fastener loose and then ratchet it off, but it seems like the box end being fixed limits the utility somewhat since the fixed end can't get into everywhere the flex ratcheting can. From what I can gather the flex joint isn't really a weak point, so why don't we see wrenches with flexing non ratcheting box ends? It seems to me a wrench with a flexing non ratcheting box on one end and flex ratcheting on the other would be an ideal solution. Thoughts?
richfinn
Leeds, Yorkshire, England
There's the Saltus wrench (a wrench with a shallow hinged socket instead of the box end) 🙂
The great thing with the Kabo wrenches is the offset, any time your using a flexhead, be it wrench or ratchet you need some kind of shallow offset for clearance IMHO.
The Saltus kinda solved this problem decades ago (minus the ratchet action obviously).
I don't know if extra long versions are available??
F
FSUwelder1212
I've seen saltus wrenches, but to me they never seemed all that useful. I kind of figured they were from a time when extensive socket sets weren't all that common. Every one I have seen seems to have a pretty deep socket/box end that would severly limit its usefulness.
RedneckWelder
The Ghetto Kingdom of Methlandia
Saltus are also taller. Many times I just need a fastener loosened to rock a bracket out of the way or loosen the bolt enough to be able to turn it out by hand and that’s where normal wrenches shine but are also limited by the angle. I would use a flex end non ratcheting box end a lot.
richfinn
I have 10mm 13mm and 17mm in Snap-On, wouldn't be without them, far shallower than a socket on a ratchet and great for front end engine work.
A flat box end on a flex would be pretty much useless, I 100% want the offset everytime.
joel63
Central FL
Are you talking about saltus or flex head ratcheting wrenches?
Sorry, I'm lost .
f121
UK
I like the idea of combo fixed box and ratcheting flex. I have the SO fixed ratchet/box combo which are brilliant, just insanely expensive.
Leaflessshadetree
Don't ask.
I've occasionally wished my ratcheting wrenches had an offset b ave open end ox end (or deep offset). My gearwrench flex head ratcheting wrenches (and many other brands) have open ends which I rarely use.
With my normal combination wrenches I use the open end because it's quicker to reposition than the box end. The ratchet elimivates that issue.
