Below 265 SQ/FT Upgrade my workshop bench table top
All workspaces below 265 squarefeet.
fishwatcher
I have a very humble Gorilla rack style workbench. Is 5’ wide x 2’ deep. It’s got some sort of 3/8” particle board top.
It’s served me well.. but I’m using my workshop for more things.. I’d like to upgrade the top. While a nice thick solid wood or butcher block top would be nice.. I need to keep this upgrade cheap. Under $100 tops (pun intended).
11E4E902-3C04-4BC7-A54B-B34B8CB1E043.jpegI might be able to get my hands on a couple of 48” x 24” 1” thick butcher block tops in my budget (CL visit today). However.. ideally I’d want it solid all the way across.
Would it be worth getting these boards and cutting one/them to fit? What would be the best way to join them without special tools? I’m talking.. I have a drill, hand tools, and a circular saw I just picked up and have never used.
I’ve seen FastCap flip bolts and J hooks that look interesting. Any other suggestions?
Ideally.. I could find one sized to fit (so I don’t have to cut it myself), solid 1.5” or more.
Something like this.. but the price is above my limit. 20143DC0-340E-4122-8FB4-8B3278B744BB.jpeg
larry4406
Northern Virginia
Do you have a planer by chance?
I have seen 2x4's plained to remove the radiused corners then glued together, sometimes with all thread, nuts, washers to pull all tight with end boards bored to conceal the internal fasteners.
F
fishwatcher
Nope. Only the most basic of tools.. most of which are on the peg board in the picture, lol. The circular saw is an old one, and I've never used one before. Trying to expand my skills here.. but not go crazy on adding more expensive tools.
jimgood
Marshall, VA
I have a bench with a plywood top that serves me well. I can't recall the thickness but it's two pieces stacked and screwed together. It's not as elegant as butcher block but once you're working on it you'll never notice. With one sheet of plywood, you can get two pieces 60 x 23 15/16" (accounting for the saw kerf).
Shiftless
East Bay SFO
I have a 7 foot wide workbench originally particle board. I found a used 6 foot long IKEA butcher block table top on C/L laid it on top and just left the remaining 1 foot as-is.
softailgarage
Bullhead City, Az.
To me, the workbench is the heart of the shop/garage. Its where you build, create and spend the majority of time at (the rest of the time is spent looking for that damn tool you just set down and is now gone). Get rid of the Gorilla rack and build your own. Customize it to what you need. Forgive me if I'm wrong, but it sounds like your just getting into being a garageaholic like the rest of us and if I'm correct, in about 6 months you're going to outgrow that little bench and will be wanting something bigger, more sturdy (like the top) and can store more ****. Build something you can be proud of, something that will be there in 20 or 30 years.
F
fishwatcher
The space I have is small. I won’t be junking the workbench, nor building a new one anytime soon. I do like everybody’s ideas here so far and totally appreciate your advice and the sentiment.
A month ago.. all I had was a tiny clamp on vise. Now I have two Wilton’s which I am restoring off of CL and FB Marketplace.
Mostly I do work on a couple of old bikes so I don’t need a ton of additional bench space.
F
fishwatcher
I’ve never shopped for plywood.. but maybe that’s what I should do. Sounds like it’ll fit my budget much better.
NDJ
BC, Canada
softailgarage
Bullhead City, Az.
Home Depot, Lowes and Sears all sell butcher block style bench/countertops, though they do get pricey. I've always preferred 1" or 3/4" plywood w/ dark brown hardboard on top. I like the hardboard (peg board without the holes), its tough, stands up to liquid spills, can be written on, relatively cheap and when its done just slap another piece on top.
F
fishwatcher
Do you just lay it on top? Or attach it somehow?
Aaron_W
I'm another plywood and masonite (hardboard) fan. Double up the 1/2" or 3/4" plywood depending on how solid I feel is appropriate, then put a 1/4" piece of hardboard on the top, usually just screwed down in the 4 corners for easy replacement down the road, although I've found it holds up quite well. The dark brown is the easiest to find, but I found some with a white top coat that I used as it give me better light. The white seems to hold up as well as the dark brown.
jimgood
Marshall, VA
I like the masonite idea. Plywood is not cheap but looking at Lowe's, you can still get 3/4" Maple, Birch or Red Oak for $80-$90 (at least in my area). That's crazy expensive compared to 3 or 4 years ago but it is what it is.
Prospecter
Maine
For your budget and goals, I'd add to the surface you have. 15/32 osb is pretty inexpensive. You could glue and screw it to the bottom of the current surface, and / or glue Masonite to the top. If gluing to the top, buy a gallon yellow glue, and spread it with a chip brush or small roller. You'll have plenty left over for another project. Use weight to hold down the surface while the glue dries. Wiltons, cat litter, paint cans, tools, etc. Anything weighty on top will hold the surface down.
Left over paint / urethane is the right coating to spiff it up if you like.
Done. Probably $50.
ZRX61
Solar Blight Valley, SoCal
If you slap masonite on the plywood it doesn't need to be the expensive plywood
jimgood
Marshall, VA
Sure. The thing about the expensive plywood is it is usually flat. The pine stuff is usually wonky and has more voids. Will that matter on a benchtop covered in masonite? Probably not.
F
fishwatcher
Patience and FB Marketplace came through.
$100 for a Husky 72” wide x 24” x 1.25” thick “butcher block” top. I used an old circular saw for the first time ever and although my cut was a little wobbly and burnt.. sand paper and strategic placement near the wall hides my amateur cut.
This is more than good enough for me. I’m happy!
