The road to hell is paved with good intentions and I feel like the house is a highway of things I've intended to finish and haven't.
Lara helped me build these cabinets in 2018? It was an attempt to add storage space to a house that didn't have much. I went overboard to make them go the full length of the wall. What surprised me was that they stayed mostly empty for years. The counter top was immediately filled and has only ever sporadically been clean. There's a psychology to cabinetry, storage and flat surfaces that I maybe still don't understand. And I miss Lara, who, while still alive, is entering the stage of needing to move to a memory unit.
When someone has Alzheimer's you never actually say goodbye. While they are lucid you don't imagine them not being that way and as they decline you reach a stage where you sense them disappearing but you don't want to acknowledge it, to you or to them. Then suddenly they're too far gone to have that conversation, to say goodbye. Like watching someone walk away in the mist.
So I spend a lot of time thinking about what's left, what can be done and what would make life better. And the answer to that for me was drawers.
Didn't see that coming did you?
To this day most of these cabinets haven't been used in a way that makes sense. Part of that is that shelves, while good for storing larger things that are shaped like rectangles, are pretty awful at smaller things that aren't. This shot shows the cabinet that was for photo gear and that top shelf held mostly chargers and smaller things like gimbals, filters, mics and what not. I attempted to force some smaller parts into the Stanley containers and it helped but you can't put chargers in them.
Last week, for the first time in months, I had a free week. For the most part when that happens I have tried to find a project that is fun and small - something with the hifi maybe. A way to escape. This time, instead of an escape, I asked myself what would make my life better.
Drawers were the answer.
I had three sheets of 18mm baltic birch that I'd been using for set tables (thank you auntie Oprah). They were already sanded and poly'd but if I didn't use them soon they'd get more damaged by the back and forth.
Part of the impetus for this project was the 3d printer and discovering the Gridfinity system. It needs drawers and I had none save for a small Ikea cabinet whose bottoms have sagged to the point of no longer closing. **** Ikea - pretty design that fails any real life stress.
I had sketched out four drawers. The end cabinets always seem to have something in the way that prevents the doors opening fully. And just writing that now makes me realize that I could easily take the doors off and build a full set of drawers to fit...
Squirrel!
To keep this manageable I decided to make four drawers that would go in the top of the middle cabinets - inside the doors. A halfway solution but one that felt attainable, could contain small things and be done in a week.
I started this process by installing a freshly sharpened blade into the track saw backwards. Surprisingly it cut but burned the hell out of the edge. Knowing something is wrong but pushing ahead is a metaphor for life.
I flipped the blade and cut sheet into the multiples of 190mm which is the number you get when you design them to be 200 and haven't cut sheet in a long time and install the blade backwards.
I measured drawers in the house to see what depth was most useful and it felt like 100-150mm was ideal so I went a bit bigger in case I wanted to add a layer like Sean did and 200, er, 190mm seemed like a good number.
As I was about to start cross cutting the lengths on the miter saw I misplaced my tape measure and grabbed a backup and found that it didn't align with my mark. I normally use only one tape for a project to hedge against errors and so I spent 30 minutes looking for the first tape and when I found it I used my Woodpeckers T-square to make a reference line at 450mm - the drawer depth.
Sure enough the tapes didn't agree and so I pulled
all the tapes out and started to check them. Most were good, a couple were out by about 1mm and one, the egregious one, was out by 2.5mm.
Bending the ends brought them into agreement and so I set the miter saws stops and proceeded to cut them all very accurately to the wrong length.
Luckily my error this time was too long as I didn't subtract my 10mm rabbet. Yay, a correctable mistake. My life is filled with those.
With all the drawer sides cut I then started to think I should do a different joining method than what I'd already done throughout the house and thankfully I couldn't think of anything better. I was feeling very rusty and used up a lot of scraps trying to dial in an 18mm by 10mm depth rabbet.
After setting up the router table I started to cut the rabbets and smelled smoke. Never saw that before and I probably should have been doing this in smaller passes. Did I mention rusty?
Once I got to the point where I was happy with the router table and my test parts had good fit I ran them all and the site of the fit up made me so happy. It was perfect and the joy that joint brought can not be underestimated.
Part of the struggle of another drawer style was to hide the joinery but I realized that I
want to see the joinery. I use baltic birch so I
can see the edge. I want to see the process - I don't want to pretend that something is what it's not.
I did that with the kitchen drawers for Judiaann and at the time I didn't recognize the metaphor but I do now. She wanted a pretty facade and I wanted something honest and functional. I will never make a false front drawer or drawer face. I will show the joint, the structure, the process.
Functionaly honesty. Honest functionality.
And dados.
Because, as you may have guessed, this took longer than expected.
Gregor
