Yea I know...Everyone on the internet wants to complain and armchair quarterback. I'm happy to take advice from others, but it's gotta be something specific that's actionable.
I understand I'm probably more of a stickler than most of their other customers because I'm that nerdy guy that gets into details and have some DIY experience. So, I'm careful to not be that annoying guy, which is why I vent my little frustrations here to get them off my chest.
Its your money and your garage, you should be a “stickler”. Your title shows you will be thinking of what you got every month when you make the payments.
Your GC should love customers like you because he should be able to prove why he made those decisions. The customer walks away knowing they are getting a quality product and he will likely get a repeat customer and/or referral.
Contractors, for the most part, just do things the way they were taught. Most don’t think about why. They move on once they have that last check and never think about how their work is holding up years later.
Putting a lift into a garage makes it more than just your average residential building. A solidly tamped base, thicker concrete, and rebar are needed to ensure safety when you have “tons in the air”.
Small changes for minimal efforts and costs can have dramatic effects on building longevity, safety, and comfort. And they limit rework when the building changes in the future.
Details like: Adding insulation between headers before sealing them off perminantly/using California corners/using seal sealer/increasing the heel hight on trusses/ensuring proper ventilation at the ridge/portal framing garage door openings/using more nails than minimum/blocking where needed/sealing OSB edging/ensuring your WRB is installed and properly detailed/adding a water ledge where the concrete garage door seal area is/large square anchor washers/H clips on 2’ oc trusses/proper sheathing spacing, etc. I could go on but you get the point. Most of what I listed is free, just a different way to do the installations.
