PWC Repair
I started in on a Rotax 717 rebuild. I removed the rotary valve drive shaft so I could replace an o'ring and the front seal. I also threw the mangled head up on the mill and gave it a smooth surface again.
And people will ask: How can it be too hot to ride? It's gotta be cooler with the wind.Too damn hot to ride this week anyway
What do you do for the ceiling ?
Ahhh,, I thought you were using a spray gun..Ceiling goes from 9 to 15 feet in that section of the shop. I'm only using arattle can so not expecting much spray to get over the plastic
People without band saws just don’t understand.lol When I was actually fabricating parts for a living I had 2, but even before that, I don’t know how I lived without one for so long.
Exactly, at less than $120 used, I find it has been one of my better investments... and it was a good road trip for the wife and I.People without band saws just don’t understand.lol When I was actually fabricating parts for a living I had 2, but even before that, I don’t know how I lived without one for so long.
Reading the family group text, new grandson is here. . . . a lil late bit he gets that from his mother...
Mopar? Usually a leak detection pump(ESIM) failing.Went out just before noon to head off to a job site, only to find "Check fuel cap" flashing on the dash of the daily. Huh, wasn't doing that last time I drove it, and it's down to 1/4 tank, so what changed? Shut it off at the end of the driveway, redid the gas cap, started up again, no change. OK... Drove to the job, did the job, redid the gas cap again, and when I started up again there was no warning any longer.
My guess is changes in temperature might have caused a pressure change in the tank, leading the sensor to think the cap was off? Don't know why it didn't correct the first time, but did correct the second time. One of those mysteries of life, I guess.
I used to be able to ride in triple digit temps. Not anymore. Low 90s is my cutoff now. My perfed leathers flow just enough air to keep me cool while I'm moving without getting dehydrated.And people will ask: How can it be too hot to ride? It's gotta be cooler with the wind.
Truth being, above a certain temperature, it's hotter because you're passing through more hot-*** air.
I learned this in Big Bend, TX. 120F was about the line--and that was before we wore the kind of protective clothing y'all have now.
Those rides were 60 some years ago. The bike, the tent, Rhonda, me.Just a couple of years back maybe 4-5? I started a hunting "scouting trip" in my Samurai with no AC, during a central valley heat wave. I got to my planned overnight camp ( no dispersed camping allowed just then with extreme fire restrictions) and the planned CG was completely full. I landed on 5 near Yreaka 7 hours from home and decided Eff it, and drove home. Most of the trip it was 117-119 degrees inside my rig. I just kept sucking down water and using a spray bottle to wet my face, neck, tee shirt, and cutoffs with water; stopping every so often for another chocolate milkshake. I was wasted when I got home...
17 hours in 117 - 119 deg temps...
No AC in the Brick, so looking forward to some hot action this summer. It hit 80 today.... I guess I need to fix the power windows.Just a couple of years back maybe 4-5? I started a hunting "scouting trip" in my Samurai with no AC, during a central valley heat wave. I got to my planned overnight camp ( no dispersed camping allowed just then with extreme fire restrictions) and the planned CG was completely full. I landed on 5 near Yreaka 7 hours from home and decided Eff it, and drove home. Most of the trip it was 117-119 degrees inside my rig. I just kept sucking down water and using a spray bottle to wet my face, neck, tee shirt, and cutoffs with water; stopping every so often for another chocolate milkshake. I was wasted when I got home...
alternator mount in, alternator tested, got a lil hot glue to help me hold wires while i route them to the voltage regulator. now waiting on a order from fcp euro for a bmw dual temp sensor and wiring for the dual electric fan since i dont think ill have room to put it all in after the alternator is in.back a couple years ago when i was working for uncle sherwin, they told us smell was the biggest tell tell on paint going bad lol iv got 15 gallons in my barn still waiting on me to finish the sheetrock btw have i mentioned how much i hate sheetrock?Anyone ever experienced this? I opened a quart of paint. Half used, maybe 6 months old. It stunk, kinda smelled burnt for lack of a better description. Otherwise the paint was fine.
Some of the oil based stuff can smell kind of burnt-ish as it's catalyzing. When the smell goes away, that's when you know the item is ready for use.Anyone ever experienced this? I opened a quart of paint. Half used, maybe 6 months old. It stunk, kinda smelled burnt for lack of a better description. Otherwise the paint was fine.
What sold me was that there is a double seal. The cap seals so if the ball leaks the oil is still retained.That looks pretty slick. If I didn’t already have Fumoto valves on everything, I’d buy one of these.
But it's latex. I did some googling. Seems latex can "spoil", especially if it freezes. This didn't freeze though. I dunno. Weird. I've opened old latex that likely has froze and never ran across this.Some of the oil based stuff can smell kind of burnt-ish as it's catalyzing. When the smell goes away, that's when you know the item is ready for use.
I’ve used spoiled paint on out door stuff that seems to be fine, but the smell alone would keep me from using it on anything indoors. I just hit it with the mixer and painted as usual. YMMVBut it's latex. I did some googling. Seems latex can "spoil", especially if it freezes. This didn't freeze though. I dunno. Weird. I've opened old latex that likely has froze and never ran across this.
