MP&C Shop Projects
M
MP&C
Leonardtown, MD
A buddy of mine has a local motorcycle shop, and he'll stop by when he gets something real challenging. Enter yesterday, his latest repair had a severe wobble on the rear wheel per the owner. A test drive verified this, and they found that most of the bearing was gone on the one side. Given the center of the wheel is smaller in diameter, he wasn't able to drive the bearing out from the opposite side and decided to see what I could come up with.
The inside of the bearing was about all we had to attach to, short of welding something to it, which normally results in cracks.
Since the size worked about right, I thought I'd try this muffler expansion tool, with some modification to add grooves...
A ring of pipe is used to keep the expansion only on the end in the bearing...
Installed and snugged to the bearing race, then a thick wall pipe that fits over the end nut of the tool is used to drive out the bearing
Success!!
larry4406
Northern Virginia
Success!!
Clever!
zmotorsports
Northern Utah
Robert, your FIL's work on that boat is stellar. I'm not a boat person but I can appreciate fine craftsmanship and that boat is a beautiful work of art.
As for the bearing, nice job removing it. Another option that I have used on numerous occasions, and since you are proficient using a TIG welder, is to weld a couple of perpendicular bead in 2-3 locations around the outer race and it will literally fall right out as the weld bead will cause the race to contract and shrink slightly.
txvwnut
Bedford, Texas
Every time I've tried to use one of those exhaust expanders in non traditional way I end up with a broken tool. Another trick for getting that race out would've been to weld a bead around the inner part of it and let it cool. Once it shrank it would've fallen right out.
The boat fits the truck perfectly.
M
MP&C
Leonardtown, MD
Had a fuel line tee for a Honda Shadow that snapped, I'm led to believe this is a common occurrence. Perhaps it shouldn’t have been made of plastic. The plastic replacement was not available until next week, so let's see if we can come up with a more permanent solution.
While I have 1/4” stainless tubing in scrap bin to make the two smaller fittings, the 5/16 fitting had to be made on the lathe from a 3/8 bolt like the one in the background.
Stainless bar stock was used for the body. Through holes were matched to the inside diameter of our tubing and then counterbored for the fittings to set into.
The fittings were pressed into place, and silver solder used to join everything together. We used a fluoride-based flux to insure good wetting with the stainless.
The corners were dressed up a bit with the Dynabride belt file, and polished up for good measure. This should far outlast the motorcycle...
zanyad
NE Ohio
:love: 🤯 :love:
M
MP&C
Leonardtown, MD
Larry, I'm not a big fan of pointy ends on body hammers, they tend to add damage the other direction. So if someone has a ding to remove, the ball end performs more of a PDR type repair than the spikes that I've removed from both these hammers. They also come in handy for concave areas or forming blisters (using hammer forms), etc.
M
MP&C
Leonardtown, MD
Since early last year, we've been making trips to the west coast to tend to my father-in-law, who has been diagnosed with dementia. We recently moved him out here to the east coast where we can better keep tabs on him and have been in the process of disposition of stuff. So sadly, the wagon has suffered in the progress department while we've been tending to life. Still plugging along on wiring and adding weatherstrip, etc. I do need to add a post to chronicle the recent cross-country trip with the father-in-law's boat...
Rockable
Oak Ridge, NC
So sorry that you and Stacy are having to go through this. Just know you two are in my thoughts and prayers.
22george
SW Ohio
Robert,
Eastwood is pushing silicone bronze mig wire for sheet metal. Have you had any experience with it?
Thanks.
M
MP&C
Leonardtown, MD
Should have the chrome plating going on this week...
Saturday the truck participated in a poker run, I had invited a friend to ride along.
He was one of those guys who appears to think that old vehicles doors don't close properly and need to be slammed. Normally I speak up rather quickly about this but thought to keep quiet to not come across as an ***. Well, as we were about to leave the 4th stop, I heard the window drop as he slammed the door once again. Didn't say anything and didn't check it until I got home. Sure enough, the window did not respond to the window crank action. Opening up the door access panel revealed that the window regulator bushing had broken where it's notched for the spring clip. So I guess this would make a good lessons-learned for anyone else out there with someone that uses a bit too much force in closing doors, those plastic parts inside aren't designed for that sudden stop at the end of a door slam.
A quick trip to the local auto parts just before closing on Saturday night was fruitless, normally I would expect this to be in the Dorman help section. The counter assistant's research showed that these were only available at Denis Carpenter type outlets, so that didn't bode well for a quick repair. Since I planned on driving the truck on Sunday, let's see what we can do to make one. Some delrin in clamped up in the lathe, turned to size and bored to fit the lift arm
The reliefs for the spring clip was added using a hacksaw blade. Highly technical stuff right here.
Relief added for the window track....
All back in place, good as new. With some closing restraint, we may get another 60 years out of this one...
I believe this to be the first time this door has been opened, but look how nice and clean a rust-free truck door is inside...
With that complete, the truck was ready for a couple photo ops on Sunday
pancholasvegas
@MP&C - Love the truck. Awesome work on the new window parts. The inner door is very impressive - I love seeing the old stuff untouched and taking a peak inside. You've got one of the best threads on here as far as technical work goes. I've said it before and I'll say it again, thank you for your contributions to multiple of the communities.
zmotorsports
Northern Utah
Truck looks great Robert, looks like a fun run.
My FIL does the same thing when he gets in my vehicles, all of them. I have to keep reminding him not to slam the damn doors. 🤬
fouckhest
Greer, SC
My wife does the same thing....even on my new truck....however, I do gently remind her LOL
Robert - that is a great quick repair on the door bushing....but did you make a spare to replace the driver side while you were at it?
Xti04
Robert I slammed the door on my dads 65 f250 as a 5 year old and the window exploded into a million pieces. Cried my eyes out waiting on the inevitable *** beating, but he restrained and it was nothing more than a cold windy ride home.
