MP&C Shop Projects
MP&C
Leonardtown, MD
Picked up the paint for it, but waiting on the new transmission adapter plate to get all the parts attached. The MDL adapter was the wrong thickness for the bell housing we’re using so we have one being made at a local machine shop. I had called MDL about making one thicker, but they said I’d have to order qty of 25. Merry Christmas!!
MP&C
Leonardtown, MD
Getting some of the wiring done behind the dash and adding the interconnect ducts between the defrost vents. This made it glaringly obvious that the speaker grille that covers this hole would show the unsightly mess behind.
We had picked up some pre-painted aluminum sheet from the local stock car supply, and here we cut out a poster-board template.
which was used as a pattern to cut out the aluminum sheet.
We found the finish a bit too shiny for what was intended to mimic a shadow, so a DA and 1000 grit Sunmight foam pad toned things down a bit.
This should do the trick..
545_days
Texas
Merry Christmas and best wishes to all who contribute to one of the best threads on Garage Journal. There are only a few threads that I make a point of reading almost every day, and this is one of them.
I have only taken up metal working relatively recently, but have learned plenty here from Robert and the many questions others here have posed that I would never have thought to ask myself.
MP&C
Leonardtown, MD
We're still plugging along with the wiring on the wagon, a couple minor details to finish that part up. I was at a local body shop to order some paint matching the state of Maryland's 1955 license plates for the one we're restoring for the wagon. The shop owner asked if I could make some patches for a step van that is in his shop for repairs.
At some point in its life someone had made previous repairs, adding an aluminum cover to mask the rust beneath. He wanted some weld-in versions in steel.
Some dies were made for the Lennox, using the same upper die but two different flavors for the bottom. One would have straight flanges top and bottom for the "rocker", and the other would have one 90* flange for a wheel arch and the outer door steps.
Note in the above picture the lower die with flat flanges has the support wings cut about 3 degrees upward. With the forming that takes place a flat die would tend to have the flanges dropped slightly from a spring back effect. These upward supports help to counter any spring back effect and ensure the flanges are perfectly flat.. sample:
Enough practice, here's a Video of the process:
MP&C
Leonardtown, MD
Robert, I assume that you always keep the tooling that is made. Do you label them, code them, and store them for future? I can see that you may never use that again for that exact part, but it might be made into another piece. Great work as always!
Any more work on the shop truck?
Yes, I have a cabinet full. Some of the aluminum parts have been letter stamped, the phenolic marks with a sharpie. Shop truck is put away for winter. I do have the paint for the new engine but it's too cold for painting. Thanks!
MP&C
Leonardtown, MD
Next on the Metro list, as can be seen in the above pictures, is the need for patches for the wheel arches. We started with a paper pattern to capture the bead details and transferred that to the sheet metal using the trusty ice pick.
Once cut out, the lower flange was hammered over by hand and then stretched using the linear stretch dies in the Lennox.
Then run through the shaping dies, the folded flange acts as the guide for the dies.
Video (sped up to shorten the time span) :
MP&C
Leonardtown, MD
Those were just aluminum plate, likely 6061. I also use phenolic and 4130 oil hardening tool steel, depending on the application.
MP&C
Leonardtown, MD
The radius at the bottom of either end of the wheel arches was a bit too tight for the dies in their standard form, I had to add a relief and neglected to get pictures..
To make room, the die was modified using a portaband to cut an X pattern, then a small screwdriver to bend the center tang back and forth until it broke free.
After the wheel arches, we had one more area to fabricate, the step going into the side doors.
Time to modify the bottom die again...
Then we started with an 8" wide piece with a 90 folded down the middle, using a .25R die. The fold was held in snug against the back of the die to act as our guide. Cut off piece was saved in case we need to weld it back on for another set of wheel arches..
These will be trimmed on the bottom to match the adjacent patches, somewhere along the sharpie mark.
MP&C
Leonardtown, MD
I was showing off my father-in-law’s handiwork, a boat he built from scratch. The outboard is a 1959 vintage, and the boat plans were from the same era. Here’s a picture I took after the show yesterday…..,
…….but it’s hard to capture the badassery of that mahogany without standing in the truck bed. Here’s one in the sunlight.
Hellpig
Southern MD
Yup, woodwork was stunning.
Wife said, " Only YOU send more time at a car show looking at boats and tractors than cars!"
My Dad had an old Merc Tower of Power on a wooden skiff a LONG time ago. But honestly, doesn't FEEL that long ago, lol, so I MUST be old
