tool_scrounge
I just was given an older Vidmar tool box, similar to the one shown in the photo. It is in reasonable shape with some rust on the bottom feet from spending the last decade in not-so-sealed shipping container outside. Eventually this will end up in the garage or possibly the house on carpet. But it is dirty and probably has a light covering of mold. The rust on the bottom feet need to be cleaned.
It is temporarily in someone else's warehouse, but it needs to leave there in a couple of weeks. I would like to get it cleaned up before then.
For cleaning the dirt and mold, what do you recommend?
Part of me wants to take out the drawers, put them in a U-Haul trailer, and high pressure wash then at a self car wash. Same for the cabinet shell. But I would not do this to the roller drawer frames with their steel roller bearings. But is that enough to get rid of the mold?
I probably could haul it outside and bag it with a ozone generator after washing if needed. Or find an discarded refrigerator box instead of a bag.
Chemical rust removal for the bottom where the feet were wet in the container seems pretty hard to do. Setting it on its side and using a orbital sander is a pain but may be a better option?
To move make it easier to move the box around, I would like to raise it up ~2" so I can just fit a narrow pallet jack underneath. I do have some older butcher block top pieces that about the right size. Is wood is a good choice? If so, should I trust the glue joints? I have seen old butcher block tops glued and then bolted together with threaded rod. I could do the same in a couple of places to augment the glue joints if need as sketched below.
