I've used this stuff for a few years and haven't looked back:
Loading…
www.amazon.com
Lays right and don't get static bound like the cheapo stuff.
Spent about the same a month ago to replace a 40 gallon natural gas water heater and a few fittings. Bradford white unit from ferguson. Ouch.Yes I was installing a new water heater yesterday. $835 hard earned cash.![]()
White tape isn’t rated for gas.Is there REALLY a difference in pipe-thread tape? It's all Teflon (PTFE), there's several colors, and there's choices in the thickness of the tape
Yes, there’s a big difference in cheap tape and pro quality tape. I prefer Blue Monster because it’s thick, tacky and has the right stretchy-ness. They sell it in many widths for ease of use on the bigger pipe and fittings. Pretty much every plumbing supply house around here carries it and it’s just good stuff.Is there REALLY a difference in pipe-thread tape? It's all Teflon (PTFE), there's several colors, and there's choices in the thickness of the tape.
The ordinary white stuff is really thin, I've seen yellow advertised as being thicker. If there's a color-code for thickness, I don't know about it. I figured every manufacturer either sells white...or their favorite color which signifies nothing except the brand of tape.
I do almost exclusively automotive--so pipe-thread tape is practically banned in my shop. I would consider using tape on compressed-gas plumbing, but NEVER in automotive use. Loctite/Permatex 592 is my go-to for automotive thread sealing.
I get that. Now get a spool of Loctite 55 and forget about all of the BS from tape.I gotta have my Teflon tape lay flat without getting all twisted up. I'm majorly OCD about applying Teflon tape...
Ain't cheap, but we bought it by the case back when we were building out the brewery. Their pipe dope is dope, too.
Yes, there is a HUGE difference. High quality tape is a pleasure to use and seals well, the cheap stuff is aggravating and doesn't work very well.Is there REALLY a difference in pipe-thread tape? It's all Teflon (PTFE), there's several colors, and there's choices in the thickness of the tape.
I have seen many people assume PTFE is a subsitute for threadlocker, anti-seize, gaskets, and many other tasks, but it is ONLY meant to lubricate and assist in sealing TAPERED pipe threads. A tapered pipe joint is truly self sealing, the threads distort to each other and form the seal, but the PTFE assists in this by lubing and taking up any gaps or small voids in the mating threads.
Flared fittings, bevel seats, swagelok, welding regulators and hoses, anything with a gasket, straight threads of any kind or basically any joint that ISN'T a tapered pipe joint does NOT need tape.
OK.Yes, there is a HUGE difference. High quality tape is a pleasure to use and seals well, the cheap stuff is aggravating and doesn't work very well.
That's what I figured.Color is not indicative of anything, really, but it can be a clue. It isn't standardized, so it doesn't mean much beyond branding.
Tape? Yes. Has no business on straight threads, or anywhere on a vehicle. Tapered-threads only.Tape/dope is ONLY required on tapered pipe threads, so you wouldn't see any in automotive use. Primarily used in the plumbing and pipefitting trades.
The (non-anaerobic) cheap brush-cap tubs of Permatex "Teflon" (PTFE) thread sealer works great on old-style steel shim head gaskets; and makes a MEAN paper-gasket dressing, for instance, on intake manifold gaskets. Gasket dressing should not be needed...until it is.I have seen many people assume PTFE is a subsitute for threadlocker, anti-seize, gaskets, and many other tasks
How difficult can it be?I gotta have my Teflon tape lay flat without getting all twisted up. I'm majorly OCD about applying Teflon tape. The stuff is already extremely difficult to work with without having the added complications of getting a static charge built up. Good grief.
Remember who the OP is and what his prior threads have been about...How difficult can it be?
I probably used a couple hundred miles of Teflon tape during my career and never had a problem with it?
Because I'm trying to get it perfect as if it was painted on. A lot of times the tape will be slipping on the threads as I'm trying to pull it tight.How difficult can it be?
I always did pipe dope, and then Teflon tape, never had a problemBecause I'm trying to get it perfect as if it was painted on. A lot of times the tape will be slipping on the threads as I'm trying to pull it tight.
I try to push it into the threads in an effort to make it stick, but it still slips. I clean the threads with brake cleaner, but the tape still slips.
An absolute nightmare.
NPT aren't, there's clearance between the crests of the one piece, and roots of the other, which creates a radial leak path. You need something -- lampwick, tape, dope, etc to seal that up. (having a gorilla install them can work for low pressure, but isn't reliable, and has other problems.) There are other pipe threads that are leak proof without something filling the gap, most common is NPTF. It has root to crest interference, so the thread itself fills the gap. They're generally single use, and are used where there's a good reason not to have dope, like worry about contamination, or extreme high pressure.. A tapered pipe joint is truly self sealing, the threads distort to each other and form the seal, but the PTFE assists in this by lubing and taking up any gaps or small voids in the mating threads.
This is true.NPT aren't, there's clearance between the crests of the one piece, and roots of the other, which creates a radial leak path. You need something -- lampwick, tape, dope, etc to seal that up. (having a gorilla install them can work for low pressure, but isn't reliable, and has other problems.) There are other pipe threads that are leak proof without something filling the gap, most common is NPTF. It has root to crest interference, so the thread itself fills the gap. They're generally single use, and are used where there's a good reason not to have dope, like worry about contamination, or extreme high pressure.
Funny, I’ve been dealing with NPT on vehicles since, well, since I started dealing with vehicles.Tape/dope is ONLY required on tapered pipe threads, so you wouldn't see any in automotive use.
Alright, I’m sure there are a few odd things that are pipe threads on automotive, but it’s relatively rare compared to other fasteners/systems.Funny, I’ve been dealing with NPT on vehicles since, well, since I started dealing with vehicles.
Certainly rare to use tape, which was the whole point of the conversation. I certainly cannot remember a time when I’ve needed to tape a pipe joint working on a passenger car.
Driving a Jeep needs some dope.Everything on a Jeep needs some dope
Check your dm!Everything on a Jeep needs some dope
It can be done. That's why Mama Nature gave us two opposable thumbs. Not kidding - you need to hold enough tension on the tape to pull it to the bottom of threads for it to cut off and seal when assembled. Can't rely on spool for that, needs thumb/forefinger tension pinch to do so.I need to be able to pull the tape tight as I'm wrapping around the threaded fixture. Having the whole roll slip makes that impossible.
And you use thread tape on those?It’s a fairly common thing in the stuff in my shop.
Oil senders, vacuum ports, water temp senders and ports…all NPT.
The intake on my Jeep pickup has three different sizes of NPT.
It works and makes taping slightly easier. Just be sure to not overdope or overtape.That gives me an idea. Maybe I need to coat the threads with something sticky before applying the tape.![]()
