Oatey Yellow Teflon Tape
tarbellb
Oregon
308guru
Is there REALLY a difference in pipe-thread tape? It's all Teflon (PTFE), there's several colors, and there's choices in the thickness of the tape.
The ordinary white stuff is really thin, I've seen yellow advertised as being thicker. If there's a color-code for thickness, I don't know about it. I figured every manufacturer either sells white...or their favorite color which signifies nothing except the brand of tape.
I do almost exclusively automotive--so pipe-thread tape is practically banned in my shop. I would consider using tape on compressed-gas plumbing, but NEVER in automotive use. Loctite/Permatex 592 is my go-to for automotive thread sealing.
Yes, there is a world of difference between the garbage tape sold at the big box stores and the plumbing supply shops. Not even close. When I see some with that **** in their hand I grab it and throw it away.
I’ve been using this for years. Available at McMaster also.
mslim
Fayetteville, AR
When I used to shoot training videos in Atlanta for the Coca-Cola post-mix (soda machines like you see in fast food joints where the syrup is mixed with carbonated water at the dispenser nozzle) department, the head tech told me teflon tape was only there to lubricate the threads, not seal a fitting.
rlitman
Long Island
That’s a good idea if you want the tape to peel right off as you tighten the joint.
The proper way would be tape and then thread sealant.
I can't say I've ever had that happen. White tape is nowhere near strong enough to handle dope being applied on top of it, but goes over a proper (not over) application of dope just fine. If your dope is as tacky as Rectorseal 5, the tape sticks to it very well, and since Rectorseal 5 doesn't have any PTFE, adding tape does help lubricate the joint.
So much institutional knowledge gets passed on that is based on superstition and misinformation. That advice is wrong. The exception about single-use crush dry-seal threads (NPTF being one example) was mentioned above, and I'll add that since soda uses stainless steel (due to the corrosive acidity of the dissolved CO2), interference fit threads are not even possible there (that's something only done in brass, and is generally reserved for fuel connections).
PCustoms
VT
I've never in my life seen a recommendation to put tape over dope, now I've seen it twice in the span of 5 minutes...
Rc_Guy
Minnesota
So about 30 years of installing fire sprinklers that get tested to 200 psi and I was doing it wrong?
Who knew?
Rc_Guy
Minnesota
I've never in my life seen a recommendation to put dope over tape, now I've seen it twice in the span of 5 minutes...
I worked with some sprinkler fitters that did it that way, but I always did dope and then tape but according to 308guru I was doing it wrong. 😆
Many times we were dope and tape sprinkler heads and some of the pipe ******* ahead of time, and my thought was always dope then tape, At least the tape protects any sand from sticking to the dope.
PCustoms
VT
I fixed my post, but dope over tape?
Really?
Rc_Guy
Minnesota
Really?
Why not?
Like I said above, almost 30 years of doing it that way and I never had any fire sprinkler pipe threads leak and I put in threaded pipe 6 inch pipe down to 1 inch pipe.
rlitman
Long Island
I'm not a fan of runny dope, but if your dope is runny (natural peanut butter consistency), then I could see it working applied over a thick tape (still wouldn't try that over the white stuff that shreds with just a strong stare). Fresh Rectorseal 5 can be this runny, as can the blue **** (not a fan at all). I much prefer Rectorseal 5 after a few years of drying out in the can when it thickens to a non-dripping consistency. And even then, I'll often brush on a layer and then give it time to dry on the threads.
Also, if you have a PTFE infused dope (Rectorseal T plus 2 for example), then there's no point in adding tape to the mix.
dr_clyde
Holland, MI
The pipefitters I worked with always used tape first, then dope over the the tape.
I wouldn't want to try to get tape tight enough to not slip over a doped pipe, but it is very straightforward to put a slick of dope over an already taped thread.
rlitman
Long Island
...I wouldn't want to try to get tape tight enough to not slip over a doped pipe...
Ahhh. I guess it's just different technique. I've always put my thumb on the end of the tape for the first turn, then roll my thumb off carefully so I don't peel up the end of the tape (this works for my purposes, but is completely unacceptable for oxygen service), and then once the tape is pinching itself, I'll tension as I wrap, so it pulls and puckers into the threads. A THIN film of dope under that helps me get the tape to stick to the pipe.
I sure wish there was a creamy sealant that I could brush on the threads with an acid brush like I do anti-seize.
Rectorseal 5 is drippy like that when it's fresh. Keep the can well sealed and stir often.
Rc_Guy
Minnesota
If I was a sprinkler fitter, I’d be using anaerobic pipe sealant with Teflon wherever possible, not tape and dope.
https://permabond.com/choosing-an-anaerobic-thread-sealant/
We would use what the company bought and paid for us to use.
It worked for my 30 years in the trade, it worked for my brother’s 39 years in the trade, and it worked for my uncles 44 years in the trade and it is still working to this day with my son and my brother‘s son still putting dope on and then tape just like I did.
I don’t know why some of you think it can’t be done or it has to be done only the way you think it should be done.
We tested the pipe to 200 psi for two hours and we tried to do it right the first time
rlitman
Long Island
There's gotta be something that replaces Teflon tape. I hate working with the stuff unless it's something easily accessible like a shower head neck.
Yes. Loctite 55. https://www.amazon.com/Loctite-Pipe-Sealing-Thread-Water/dp/B0010YLI0G?tag=atomicindus08-20
It makes tape completely obsolete.
Soft setting and non-setting dope are repair friendly. Tape is a mess when disassembling, but isn't too terrible to clean up. Setting dopes and anaerobics are very repair unfriendly. If I'm ever going to think about fixing it, I'm not using one of those.
In my neck of the woods, almost everything with fire sprinklers is done with roll-grooved fittings (or we. There's very little NPT to be seen, so all this is moot.
KnurledNut
n/a
The ones I posted are designed specifically for use in that industry with service and repair in mind.
Lots of old works out there to maintain.
Regardless, its still another option to consider for metal pipefitting that had not yet been mentioned in the thread.
Firebrick43
West central Indiana
Mill rose has had the blue monster tape in yellow for years, the just called it “3 Wrap”. Recently they have rebranded it as the blue monster brand, our Menards already has it. It’s the best Teflon tape I have used. Both blue and yellow. We pair it with rector seal 5 or gasoila for propane tank NPT fittings that see 250psi without leaks. It’s also the 1/2” wide that is much cleaner but 3/8 would be better
I still prefer loctite 55 but I always forget to order it before running out and it’s not carried anywhere locally. Loctite 545 on hydraulic fitting as Teflon carries the risk of screwing up hydraulic spools, pumps, and valves.
Supply house Gas Tape
cannuck
Rural SK
My go-to. This on top of some quality tape and there's never a problem.
My fitting supplier recommended that for what we do/did (hot napthenic oil and high vacuum). So, I built an entire process skid counting on Gasoila as the sole sealant. Worked fine...for a few hours. Once it got hot I had leaks all over the place - and days of work to disassemble and rebuild using petrotape.
Junkman
Northeastern CT
Because I'm trying to get it perfect as if it was painted on. A lot of times the tape will be slipping on the threads as I'm trying to pull it tight.
I try to push it into the threads in an effort to make it stick, but it still slips. I clean the threads with brake cleaner, but the tape still slips.
An absolute nightmare.
That is exactly what Teflon is supposed to do. Make things slippery.
