Hello, I have acquired a Rockwell Drill press #15-665. The internal wiring and cable was in bad shape so I've replaced all of that but I kept the original push-button switch which I'd like to remain operational.
I'd like to add a RS-1-SH drum switch, and had a question about mounting the switch. What approaches do you suggest?
The pic below shows the motor and junction box housing. I have a few possible ideas:
- A metal plate similar to this: https://www.garagejournal.com/forum/threads/atlas-63-drill-press-restoration-resto-mod.489265/ https://www.garagejournal.com/forum/attachments/20220521_tools-d75_7416-jpg.1666869/ that goes between the motor mount and the head.
pros: It would be facing forward and at a good height
cons: I have to fabricate that plate which I don't really know how to do
- I could drill holes in the metal plate covering the junction box and mount the switch to that.
pros: Easy to do
cons: the switch would be facing sideways, and while the metal junction box cover is solid, it wasn't really designed for this purpose
- Create some sort of system that mounts it to the column
pros: The switch could be a bit closer
cons: more complicated to figure out the mounting approach
- Something else?
