Truss repair
mm08822
Unfortunately, gentrification is becoming the norm in many neighborhoods. Im seeing so many perfectly fine homes from the 40s-70s getting taken out entirely and a new build going up in its place. Renovation isn't even a consideration.
Talk about erasing history!!!
mike93lx
Richmond, VA
Yes, we should go to great lengths to save all the incredibly well built houses that were slammed into neighborhoods in the 50's-70's
Bert_
NW Iowa
Many are decent, liveable houses. Just seems nuts to simply tear it down.
dscheidt
Huh? Can you elaborate?
Basically, each truss is a stud on the side walls, plus two rafter elements, sometimes a collar tie. All the joints are done with plywood gussets or metal truss plates; the top of the studs are cut at an angle so the rafter bears on it (rafters may get cut, too, not sure). the bottom of the studs are attached to a foundation wall with connectors, or a wood frame done like a normal platform on post and pier foundation. If on a platform, the studs extend through the decking, and attach to the side of the rim joists.
Everything is built on the ground, and then stood up, which means the trusses can be built in advance, possibly by a single person, and then everything stood up when help is around.
The distance you can span with this sort of thing is pretty small, but it's clear span. I've seen a number of narrow and long drive sheds built like this, probably in the 60s.
WisJim
Menomonie, WI
There must have been some government or lumber association pamphlet on how to build them.
I think that the American Plywood Association published pamphlets about building trusses like this, but I'm not home to look for it, but they were quite specific about size and grade of the plywood gussets and nailing pattern, etc.
Bert_
NW Iowa
Tear what down? The house in that video? What was the condition of the foundation? Any mold? Water damage? Termite problems?
No idea about that one, same as you.
We as a society seem to be more and more ok with just throwing everything away when it is no longer up with current fashion. It's a trend I have a real problem with.
KenC
My Dad was in a federal government training program for veteran farmers/ranchers right after WWII. For years I had his text books from some of the classes. One was on self-built farm buildings. It included mixing concrete and building trusses just like that.
Size of the gussets, nail gauge and pattern were specific. I've actually built a few to fill in missing spaces when the truss company didn't meet schedule. Easy enough, but lots of nailing and technically gun nails aren't OK as they are smaller OD and finding the right length is difficult. I cheated and used the longest nails my shingle gun would shoot. They are close to the right gauge and I like to think the big heads help.
KenC
Where the trusses are separating, I would make steel gussets out of 12 gage sheet and screw them into place. Then add a header beam across the posts under the trusses fastened with carriage bolts through the posts.
John
Looking at the pic of the separation, I'm not sure it is separating. May well be just the original cut was a little short so they spaced it to the needed length. Would fit the overall DIY workmanship..
tarmy
Nor Cal
Sooooo…you wanna put duct tape on this and call it home. OP…you really wanna sleep and live, with family or guests it that?
Lots of good comments. Those trusses are not something you should screw with…may just make things worse. Good luck.
matt_i
SE Michigan
I am trying to figure out how to fix a problem I got in pole barn I'm converting to home. Was built a long time ago, unknown of year built, no permit was ever pulled prior to building. Currently have 2x4 common trusses, 4/12 pitch, spaced every 4'. Pole barn is 32' wide (1' overhang on each side) and 48' long. Recently dug out concrete footer to make building code for home, prior posts were in dirt. Trusses in middle are starting to sag/pull apart. How do I fix the issue so I can move on.
Don't know truss manufacturer. I believe the truss isn't sitting on header of wall where it should. How do I fix without judgment ...
This is a "tin skin" which is pretty bare bones. If you wanted to fix what you have I can tell you how to do it. If you are considering upgrading this building to more serious uses, I would consider a ground-up look at whats happening.
As far as how to fix the bottom chord separating, from an engineering standpoint, you need to pull the members tight along the axis and then secure with more substantial attachment. First is to brace existing loads so it does not fall apart on you. I would start with something like Jorgensen I-bar clamps, I think they are still made, I have some 6 footers. I would screw some metal blocking to the top and bottom of each member with GRK-RSS 5/16" screws, on the top of the member and on the bottom of the member. Same thing mirrored on each side of the gap. Before tearing the plywood gusset apart, I would ramp up pressure and you should be able to see the gap starting to close. Assuming that is happening, then you can have confidence that the clamp is capable of bearing the tensile load in the bottom chord and also overcoming it to close the gap. The loads supported by the truss are fairly small, its basically just the weight of the timber in the truss and the tin skin.
Assuming that is working as planned, the next step is to tear off the plywood gussets. Replace (and sister existing bottom chord joint) with straight 2x material both sides of equivalent height, I would go for 8 ft timbers. Apply construction adhesive, I would use Loctite 8x. And finally, more GRK-RSS screws driven from both sides into the clamped sandwich. I would use a length of 4-1/8" as that will also secure the opposite sister as well.
firebirdparts
Kingsport, TN
FWIW that is not a truss. Wrong word. Not close.
matt_i
SE Michigan
Also, if you were interested in beefing up the building, The connection for "every other" truss to the top of the wall girt can be improved. There is probably a Simpson strong tie connector you can adapt for use. I would recommend (if you have the capability) welding up 1/4" x 2" steel flat bar, lets say 6" long. Punch or drill for 3/8" holes. Put in place and measure the angle by scribing or setting a reference protractor. Weld the parts together, now you can clamp and drilll thru-holes for hex bolts or you could not-drill and use GRK-RSS 1-1/2" screws, although the 3/8" clearance hole in the steel might have to be downsized. If you were able to accomplish this, the building would be better prepped to survive severe weather events.
rust in the eye
Chicagoland
Hire an engineer or remove the roof and reinstall with properly designed trusses.
Those aren't sufficient for an ag building, let alone a house that will need a ceiling installed.
I'm struggling to see how any of this will be better than starting over
+1
I wouldn't live under that roof.
The Cobbler
Since the original poster hasn't been seen for 72 plus hrs. at this point and all of his posts were within 30 minutes of his joining... I think we can safety assume he had nothing better to do that night than play with us.
PCustoms
VT
Never saw that coming
Firebrick43
West central Indiana
Midwest plans service did as well, part of the extension service that was sort of a Co-op in the midwest. I am quite familiar with them, no way in hell did the builders of OP's barn follow them.
PoorUB
Fargo, ND
Or he doesn't want to hear the truth!
That building he asked about needs to go away before it goes away on its own!
JuncleJohn
Omaha, Nebraska
I would not tear it down, but re-enforce it and use it for its original purpose. As stated many times, it would probably be less expensive and less of a hassle (permits and inspectors) to build a new structure for living quarters.
Living in the Midwest my whole life, I’ve seen way worse built barns and sheds that have withstood decades of cold winters and hot summers.
Not everyone has deep pockets to build from scratch. Many need to make the best of what they have.
However, I do not recommend using it for living space.
John
NUTTSGT
Northern Central Ohio
I would suspect they are separating because the roof is sitting on the top chord of the trusses. With not having the bottom chord sitting on anything, there's no place for the bearing weight to rest, so the entire truss is sagging.
I'd also hench a bet that building is old enough that the metal roof was nailed on. If it's sagging that much that it needs repaired, I would also suspect the metal skin is tearing around the nails.
I'm no construction expert but I do know if that structure was involved in a fire, those trusses would be worse than some modern lightweight building trusses. I'd probably keep my guys out and fight it hard from the yard.
kwb
PNW
Since the OP has never returned I will weigh in in this.
First rules of real estate are location, location, location.
If you find a spot you like but no suitable houses for your needs you have 2 options, massive remodel or tear-down. Usually if you can do the tear-down without triggering a whole slew of additional red tape you are going to be way ahead just spending ~$15-20K and a day or two to put the old house into a couple of waste containers and start from basically bare dirt.
Lots of suburbs that were "out a ways" were built with smaller houses so those with less income could commute into the main city. Over time those satellite communities developed into a city of significance and the basic post-war 3bd 1ba houses that were there aren't highest and best use of the property.
I get your house is an emotional thing.... to you. For the next person it is almost always first a financial decision that they will eventually get emotionally attached to.
None of this is new, just look to Europe where they find all sorts of ruins of old buildings that were built over the top of.
Progress happens.
reader2580
Minneapolis, MN
Not all are. I tore down a 1911 house that was absolutely falling down, and built a new house that cost $190k to build in 2001. It was a decent house, but not huge.
The house was 850 square feet with five additions. The crawl space had been poorly converted to a full basement, and some joists were dangling in the air. The bathroom was an addition built on the property line. The toilet was falling through the floor. The roof had multiple layers, and was leaking badly. The roof had blue tarps all over. The only person who came to look at renovating the house told me he knew a guy who would burn it down.
I went to the city to get a demolition permit. The guy said the house was going to be condemned, but the owner put it up for sale. He couldn't give me the demolition permit fast enough.
Uncle murph
Harford county
No inspector is going to let those slide without a engineers stamp.No engineer is ever going to give you one. You might possibly install new engineered trusses next to the old ones and then remove the existing ones but I can’t see the benefit to that.
