supermoose
- Joined
- Sep 22, 2025
- Messages
- 15
I'm back and finally have a signed contract with the builder for a 30x40x16 pole building/garage. For cost, I opted to not include the mezzanine for now (can be added later) and skipped the insulation and finishing of the walls. The ceiling will be insulated and finished. Half the structure will be 6" concrete for a lift and the other half 4". The building is not next to the house (roughly 100 yards away) and will serve as a workshop/garage for cars that I don't use on a regular basis (storing my truck when I'm not driving it and my classic Mercedes), storage, and a place to do reloading (although without some way to control the heat, powder and primers won't be stored up there to start).
I had a few questions as I'm still trying to plan a few things out that I was hoping for some direction on. Located in SE PA.
Thanks!
- Radiant in-ground heat.
- I know if I do this, I'll need to insulate under the slab. A complete system right now would be cost prohibitive but I was toying with the idea of potentially doing the insulation and running the pex for the future. I know I'd need to mark out a general area where the lift would go to avoid drilling through the lines later. Currently there is no gas line at the building, which means I'd have to see if a line can be run or put a propane tank up there. Thinking along these lines, I presume that the boiler would also provide hot water for the utility sink I plan to put there.
- Forced hot air
- If I go this route, does insulating under the slab make sense? Is there any material gains from doing that? Am I losing anything by not doing radiant in-ground heat?
- Frost line insulation
- Regardless of which heat source I choose, should I insulate along the sidewalls of the building down to the frost line? Is there any advantage to maintaining the temperature in the building by doing this or is it solely to prevent heave in the slab? It looks like in my area it would be 30-36 inches.
- A/C
- What would be the best way to cool the building in the summers? Mini split? Something else? Not looking for it to be frigid, even in the mid 70's would be great, more concerned about humidity.
- Lighting
- Any suggestions for overhead lights that won't break the bank?
- Garage door openers
- There will be one 10x10 door and one 16x8 door. What openers would I be looking at?
- Stubbing in water line
- Is this pretty much wherever I want to place them? My plan is likely to collect rain water and bury a cistern since I can't run water from the street and trying to run a water line from the house will likely exceed the cost of a cistern. That will likely come later, however, I need to do that before the concrete is poured.
Thanks!
