How thick metal can a dremel tool cutting wheel cut?
mikey03
If it matters I got a m12 fuel dremel. Wondering the max thickness of metal I can cut through with it. I tried on some shelf brackets and I got a little through it but seemed like it exceeded the tool limits so I stopped.
jblnut
In the Middle of MN
4-1/2” angle grinders are pretty inexpensive these days. If you plan to do any actual metal work I’d invest in one.
To answer your question I’ll ask another. How thick is paper ?
strength_and_power
Depends on how often you plan on cutting metal. 1-2 times a year, I’d probably suffer through with the dremel. 1-2 times a month, M18 4-1/2” angle grinder with a good quality cut off wheel. More frequent and thicker material, I’d go corded,
MovingAlong
It's really a question of "How much patience do you have?". :dunno:
If you're considering a new M12 tool, I'd be looking at the Hackzall:
Or the Band Saw:
Pricey for my needs, but I really want the band saw! :love:
