J H Williams vintage hand tools
The frustrating thing is finding an adjustable with a screw that has no slot - it's just a pin driven in with a friction fit. Can't get those apart!
Somewhere here, I found a post that says to whack it on a board, pin down. The sudden stop will help encourage the pin to move.
Obviously, do this over a box, in case the pin is really looser than you realize. On the 4”, you may need a cheater pipe to get the velocity up without mashing your fingers
If I am able to remove the screw, I disassemble the wrench to clean it. If I am unable to remove the screw, I just clean it up as well as I can. I found this 8” adjustable today and will start the cleanup soon.IMG_8672.jpegIMG_8673.jpeg
I was able to take this one apart after it came out of the evaporust. It needed a bit of work with some files for the jaw to totally close. I buffed up the polished chrome area. IMG_8711.jpegIMG_8712.jpegIMG_8713.jpegIMG_8714.jpeg
nz44tool
New Britain CT
I've tried that method (arm movement accompanied by some choice bad words) with no success so far. Those little pins don't have a lot of mass to accelerate.
MR.X
So I did not research this before posting but I bought 3 dirty ratchets for $2.00 total today at a Dearborn yard sale, a Husky Kenosha, a Bonney and this, which I thought was going to be a Williams by it’s shape.
Steven 33
after a few years offered, there still is a $100 reward offered for a oval logo no. 1 engineers wrench that meets my display expectations. its the last 1 needed for my 1914/1924 "silent salesman" senior retail display board. thx. DCRUTT ended up having a 702. DSC02543.jpgDSC06295.JPGDSC05173.JPGw wench.jpg
I have one somewhere. Commenting so I remember to look
Steven 33
One side says 528 and the other very clearly says 529. Pretty sure it's a 528 though. I think lugz posted a 529 at one point and it was a different size
Ayrhead
Ontario
I came across a J H WILLIAMS #438 face pin spanner wrench. I believe the spacing between the pins is 3 1/2”…
I won’t be using this tool, just adding to what I already own.
I do a quick search through some catalogs on the Archive site… the 1959 was too old the tool logo was different, the 1989 catalog picture didn’t match either. The 1976 catalog did look pretty similar so I’m going to guess that this tool was made in the mid 70’s.
Ayrhead
Ontario
Yes, I agree… I think there would be a lot of scraped knuckles as well as quite a few choice words spoken while the scraping was happening…
