I would just leave it sit the way it is, even if not tracking it anymore. Duck would be the second vote, though.Alright! The '81 is just about prepped to make the journey. After putting the new fuel pump in (along with a filter and accumulator), she started up nicely. I've never really liked CIS fuel injection but I'm feeling much better about it now. I removed the megaphones and swapped a sensible muffler on it. I want to have heat in this car eventually so I'll likely get a set of SSIs with some kind of sport muffler. I wasn't comfortable driving on pretty old Hoosier R6s that had 4+ heat cycles. So I had the original phone dials that I can use for the drive. I not looking at the date codes on the tires! They just have to go 90 miles...
The brakes were squishy so I flushed the system with some new fluid. For good measure new oil and filter too. I do have a few oil leaks that I'll need to sort out - maybe head studs? I had plenty of fun beating on this car at the track so things like this are expected. It'll mess up my new floor!
I took it around the block, warming things up and just generally checking it out to be sure I'm all good. It is much faster than I remember. I had to double check my speed via GPS because I thought the speedo was off by 15 mph or so. This is definitely faster than the 3.2L carrera's I've driven in the past few years. Or at least it feels faster. This has the euro spec motor with 9.8 compression, larger intake runners and ports, etc. The end result is it's supposed to make 204hp and 197 lb-ft compared to US spec of 180hp and 175 lb-ft. That's roughly carrera numbers with more torque hitting a little earlier in the band. I don't remember what the corner weights were, but this car is probably 2550 lbs including about 100 lbs of ballast I had to run to make weight.
The headers and megaphones before
Took the muffler from my original '72 motor - was not easy getting to the bolts when on a furniture cart.
Needs a wash - and have to go to the DMV to re-register it. Just a tad expired.
Body wise, I'll go back to the original front bumper setup and relocate the oil cooler back into the fender. I will definitely remove the big IROC wing - maybe go duck or naked?
Yes, I think it is platinum metallic. This car has had some prior (poor) body work. I can see drips around one of the doors and then some messy work around the engine bay. The front spoiler and iroc wing were rattle canned by me with the closest match I could find at the local auto parts store. Who knew those fumes would give me headaches?Is the '81 Platinum Silver Metallic?
And for the record: keep the front lower valence as is and add a Duck, or original bumper and naked.
I really wanted the 5G back for my system but didn't want to pay for 5G internet monthly. I had no idea you could buy yearly per GB packages. That is awesome and I am going to have to look into that then.And yet more for the home networking and security geeks. The Unifi setup is working flawlessly...zero complaints. The networking stuff is rock solid. The comcast/xfinity reliability is not. It is down here and there a couple times a month. Sometimes just for a it, sometimes for longer. Fortunately, Unifi has a few options available. Yesterday I installed a 5G backup device. Plugs into any POE network port (I used the POE switch in my workshop) and it gets 5G service over T-Mobile. The device was $99 and I bought a 10GB/year data pack for $60. It is used as a backup/secondary internet and cuts over automatically, switches back when Xfinity is restored. I'm only 1 day in so haven't truly tested it yet but in theory I'm all set.
The camera security is great. I record everything all the time so I can go back at night and see why the dogs were barking at 3:30 am (they heard coyetes howling). I've also done things like building an integration into my Home Assistant server that allows me all kinds of flexibility. For instance when a car comes up the driveway and crosses a line - the Ubiquiti camera can detect that and send an alert through the Ubiquiti app. But I can take the a step further and trigger an action in Home Assistant. Right now I have it play an alert sound through all the Sonos speakers in the house - that way we know someone is arriving even when watching a movie, sleeping, out working in the shop, etc.
Audio alerts for vehicles entering the driveway is a great idea. Going to have to see if I can get that up to play through my Google Homes that are in every room. Long term I need to get something that lives completely local. I want to switch to the Home Assistant voice boxes but it's going to be a costly conversion with 10 Google Homes to replace.
Yes you are correct, they do show up as music devices. I have an action to make my doorbell play through all of them already so shouldn't be hard to create a speech alert for the driveway as well. Adding the cellular internet back would actually be a good middle of the ground work around to prevent losing access to Google servers if the primary internet drops out.You'd be surprised what you do via Home Assistant. My Sonos devices show up as media_player entities which allow me to push the audio out. While the Google Homes can't run locally, you could still use HA to push sound/music to them via Google Cast. So that'd be an intermediate step until you eventually move off the 10 Google Homes. I think they show up as media_player entities as well.
Make it yours and drive the snot out of it!
I think used and refurbished/recovered seats is the answer!
@kwyjibo might be able to help with a trim shop recommendation in the DEN area.
Yes indeed! Autoweave seems to be almost caught up at this point. Our mutual friend who just rebuilt his SC motor is getting his Land Cruiser seats recovered by them soon and I only brought him in there to meet Ron a couple weeks ago.I think he used Autoweave...who I have used before to restore and leather wrap the dash in my '72, and they've done work on my brother's interior. Great work that likely can't be beat in Denver but their current lead times and pricing might have me trying to find alternatives...
Makes total sense. And I think the whole point of this one is to do exactly that - drive the snot out of it. It won't be worth much or pretty so I won't care too much about how it is treated.Make it yours and drive the snot out of it!
Someone makes a speaker insert for the dash location that has two small speakers. I did that, then added door speakers in my '72 with a sub and small amp under the passenger seat. The amp has a tuning mode that helps balance the sound between the speakers and I think the sound is alright. I did the same amp and sub in my Urq and am pretty happy with the way it turned out. I haven't made any stereo config decisions yet on the '81...but I do have a Blaupunkt Bremen sqr 46 dab radio that looks period correct but has bluetooth, etc.When I converted my '72 back to street from race car I didn't even bother with a radio. That little 4" speaker in the dash just doesn't cut it and I wasn't going to add speakers.
My 914 has a great little sound system.
My 02. Since you didn't ask.Someone makes a speaker insert for the dash location that has two small speakers. I did that, then added door speakers in my '72 with a sub and small amp under the passenger seat. The amp has a tuning mode that helps balance the sound between the speakers and I think the sound is alright. I did the same amp and sub in my Urq and am pretty happy with the way it turned out. I haven't made any stereo config decisions yet on the '81...but I do have a Blaupunkt Bremen sqr 46 dab radio that looks period correct but has bluetooth, etc.
russellbuiltfab.com
russellbuiltfab.com
10:30am...I knew I liked you!Pouring another...
Slicktop lol. The only way!My 02. Since you didn't ask.
No radio/speakers. Easy. IF you have to have music - Air pods/phone. If the engine and muffler are making glorious noises no need for another sound track - plus how many other cars do you have that have music - right tool for the job.
Leave the wing - you have a cage - make it street friendly - Recaro SPG's - get rid of everyting else. Its a fair weather car.
Then call thes guys - https://russellbuiltfab.com/ Black fender flairs - just bolt'em on, black headlight trim rings, black mirrors.
Got to have these wheels -
Baja Wheel - Russell Built
The BAJA ONE and BAJA LITE. The perfect blend of classic Porsche Fuchs and European rally.russellbuiltfab.com
All yur ideas are here -
Sportsman Safari Kit - Russell Built
We’re thrilled to announce our Sportsman Safari kit for Porsche 964 models, now available in a kit form for you or your trusted shop to install. Thisrussellbuiltfab.com
Flares, wheels, lift, tires - DONE. Fabricate your nerf and safety bars at your will. Fun welding project, rattle can black. Hit the fire roads, grab your Go-Pro and hoon for therapy in the evening via sunsets. There are a metric F ton of killer roads like that around you.
And by the way - the hardest part is done - SLICKTOP!
Enjoy.
Pouring another...
Yessir! That's one of the areas that I might need to change. I'm leaning towards a coilover safari conversion from Elephant racing. They spec it with their RSR adjustable sway bar package (I think these are the same as the Tarrett RSR) which I think has much thinner bars. I assume the safari setup will need to be softer and I don't have much adjustment range left to soften the Smart Racing bars. It looks like Jerry Woods now sells the bars under their name in 4 sizes. I just measured my rear ones and they appear to be 28.6mm? Anyhow more digging to do there to see if I can salvage the bars I have. I bought them a long time ago and had them on my '72 before I tore it down to restore it.I've got Smart Racing bars on one of my '72's that I used to race. They are the size of a baseball bat. Car corners very flat, occasionally it will lift the inside front wheel.
You get the cage cut out yet? If you haven't ...
Porta band saw would be the best way to get big pieces out fast (slower speed cutting) if you are not trying to save any of it. I'd cut the door bars out first for better access and working space in the door area and go from there...The hardest part will probably be where the cage ties into the chassis/ floor. I figure that will be where the welding blankets and grinder will come into play.
Good bit of grinding/ cutting to get those 6 tie ins out, that's where the real work is,looks good so far![]()
Not sure if you want the story or finished product but heres the short story. Started as a track toy. Then bought the '81 to take over that duty and began the rebuild on the '72. That led to my wife deciding I needed a bit more garage space so I moved into a 16x45 RV/garage condo. The end result - fixed all the rust, welded on flares, had it painted (slate grey), and reassembled from the ground up. 3.6L v-ram motor. Did a mostly light weight build - under 2300 lbs. Now I just have fun in my version of an RS clone. There's a very similar one on bring a trailer right now with a day to go...Small request..more pictures of the black car in post #419
