Shopvac hose adapter
Tynee
In the Heart of the Bluegrass
Good evening. I’ve bought a new shop vac with 2-1/2” hose. I’d like to be able to use my old 1-1/4” hose and attachments to extend the hose. Google and Amazon are only getting me various versions of this:
I feel like the hoses will slip off each end of this. Are there better options that will give a more positive connection?
Push harder, keep the vacuum on.
Every shopvac I’ve ever owned or use came with those fittings to keep the crevice tool, dust brush etc on. Only fail randomly occasionally.
I have so many 1-1/4 “ house vacuums with a fancy catch, just drives me bats#1t.
vavet
Ashland, VA
You’re going to lose some suction if you use a smaller diameter hose. I’ll agree the shape of that thing is not optimal, I’m not sure what your actual objection to it is. i would guess there’s a bit of a taper to the shapes so they inert easily, but you still have a firm connection. if it falls apart, put it back together and give it a wrap of duct tape.
alternatively, buy a 3dprinter and make the fitting you want,
kbuhagiar
Escondido, CA
All of my wet/dry vacuums use similar connections, with the same style of adapter, and they work fine. The ends have a taper which make for a snug fit.
It's Amazon - buy it, try it, and if it doesn't work for you, send it back and get a refund.
Wamsutta
Amarillo, Texas
I went the opposite direction you did. I got the hose kit first and then went searching for a garage vacuum to fit it.
T
Tynee
Make sure one side is able to screw on to the hose
That's exactly what I'm looking for, but my small hose is 1-1/4" ID. I'm not certain it will fit my smaller hose, but I've picked up this and a couple other options, will see if I can cobble something together that works better than my last experience.
Thanks all!!
Dig Doug
Thanks all!!
1.5 outside
1.25 inside
Dig Doug
Post back I’m curious …
the rt side pic shows the black vac hose
outside of the adapter on the top
and
inside the adapter on the bottom
bonneyman
Desert SW
Perhaps something like this would work? I saw it on a Utube video of an HVAC guy using it on his battery vac. Allowed the use of the standard pipe fittings with a variety of vac suction ports.
I figured if it got you close you could adjust what you've got to fit.
T
Tynee
and
I should have gotten pics, but didn't. My 1-1/4" ID hose didn't fit on the smaller side, either outside or inside the small end of the adapter. A bit frustrating, since this is exactly what I need, just not the right size.
Firebrick43
West central Indiana
I don't, my kid does. That may be the way I'll have to go.
Most hose connections have a taper. I simply put a piece of tape down the side and measure and mark a distance on the tape down from the tip. Doesn't matter the distance as long as you know it, say 1". Then at the tip and the mark measure the two diameters. Make a profile drawing in the CAD program from a centerline and revolve it.
If you need help with the CAD side let me know and I will get you an STL or 3MF to print for your set up. It takes just a few minutes.
