trailer adapter splicing- connector
CADjockey
Good Evening!
Just a quick question. It has been a while (long time) since I have had to do any kind of wire splicing.
I am rewiring/making an adapter cable (6-pin square plug to a 4-pin flat plug) for a recently purchased used trailer. The trailer has a 6-pin plug but no electronic brakes have ever been on the trailer. I have a decent multimeter to verify good continuity.
My question is what kind of splice connector would you recommend? I have some crimp type connectors, and some shrink tubing. Is soldering recommended for this application?
Chuckster in NJ
Hunterdon County NJ
yatg
Southern Oregon
matt_i
SE Michigan
I would not ever use a **** splice other than this one (there are 3 variants for different wire gauges). Moisture will inevitably find and corrode standard **** splices or unlined heat shrink tubing in an outdoor app like a truck or trailer, and we all know how that goes when you are attempting to hook up after dark. This one has a "hot glue" which also melts to seal the connection. One has to crimp responsibly with the proper tool and resist the temptation to use a pliers which will gouge a hole into the jacket as the tube is being crimped.
Agree with 100% on using nothing but industry standard 7- and 4- way connectors.
C
CADjockey
Cut off the 6 pin connector, get a 4-flat stub, use **** crimp connectors to connect the stub.
Stagger the crimp connectors so they're not all bunched up.
Slip on some wire loom for a finishing touch.
If you ever decide to put brakes on it, use a 7-round like normal people do.
The 4-pin flat will plug into a 7-pin round adapter that I already have for the truck. I just need to have some way to use the wiring on the trailer. For whatever reason that is using the 6-pin square. Up to this instance, I had never seen one before. It is built into the trailer frame, so it is rather tidy, but I would agree, completely non-standard.
PCustoms
VT
What the hell is this sorcery
I would get something like this (random endorsement, might look for a "better" one):
And one of these
To make an adapter. Or just cut the 6 pin off and use the 7 pin plug on the trailer
cgrutt
Does trailer have electric brakes or need auxiliary power? Is it a camper? I'd leave it and buy an adapter.
yatg
Southern Oregon
In the frame? So there's no pigtail?
Must be somebody's idea of a better mousetrap.
Some pictures would help on this.
As above, cleanest is to rig up a 6-square to 7-round out of available parts.
C
CADjockey
That adapter is exactly what my end game is. Well done finding that!
After shipping and tax, it looks like it is $62 and change.
I had found an old 6-pin square female connector (the colors of the wires are not matching current 'standards', but the location is correct) and a 4-pin flat make connector. I already had a standard 7-pin round to 4-pin flat flat adapter plug, so I was trying to make an adapter cable to go from the 6-pin square to the 4-pin flat. Like it was suggested, I had planned to cut the wires on each then splice them together to make the adapter cable. I do have plastic spiral cord wrap to give it a nicer finished look and to provide additional protection.
Many thanks for the comments!
ADDING A PIC OF THE 6-PIN CONNECTOR IN THE TRAILER FRAME
theoldwizard1
SE MI
Yes, it will verify continuity, but always test after with the bulb in the circuit !
Solder not required.
Personally, I prefer non-insulated slices and marine/dual wall heat shrink.
C
CADjockey
Just wanted to let folks know I finished the adapter cable.
I took two plugs, and spliced things together, making sure wires were matched correctly and the continuity in the cable was good.
