Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
So I showed a picture of a couple of outlets and 2 gang boxes. We'll between a few chores yesterday. I tried to get started.
Notice the plate covers are now painted black.
I'll be replacing this outlet for with a double. I thought i would be fine when I wired this place but as I have progressed to doing all my metal fab, the drill press and bandsaw use the same outlet. That leaves no room left for anything else.
N
NUTTSGT
Breaker off and outlet removed.
This is when I remembered I used new work boxes. These hook around the stud and fastened with screws...not coming out.
Fortunately, I had some similar boxes, Canex as the others were Carlon. Looks like I can just hook the 2 gang boxes on after opening the hole in the plywood.
N
NUTTSGT
I robbed boxes from my stockpile for a future build so I needed to replace them. So after supper at Jersey Mike's, we stopped Menards.
I grabbed a few other items while there but I also mowed last night knowing I work today.... and picking up a shift tomorrow.
I also talked to the wife about a road trip to CT. She wasn't keen on the idea so the auction on Govdeals will remain just "watching" rather than bidding.....
However, I did bid on a similar item closer to home, in state...just lighter duty.
N
NUTTSGT
In the mean time. .... when I went to my parents, I needed a 12" crescent wrench....okay adjustable wrench for the locking nut on the upper for the 3 pt. Since I put the box blade and never had the backhoe off, I never needed one. Wanting one that would stay with the JD and having a credit at The Jungle, I put one in the cart and decided to buy an even cheaper one with the remaining balance. 20260720_083624.jpg
I decided to leave the black one in the Deere and it fits right in here. Yes. That is a tourniquet with shears in the pouch. Just in case....while cutting wood.
Yeah, I love the Farm Sip Supreme too.
N
NUTTSGT
Its sitting in place for now. I'm considering switching a few things around but its going to have to wait a few days. We'll be doing a few things with the older grandkids so no garage time at the moment. I did install the handle and add the wood top.
As a bonus, the shipping pallet is now kindling for this winter
N
NUTTSGT
So now I have a brake to sell, a brake to clean up and add a shelf to the base.
I finally got the 56" box to put all the tooling in I bought last year at a NY auction but have been to damn busy to sort it out. I dig pick up some drawer organizers and liner material for the tooling. Its probably not enough but it's a start. Its just a lack of available time. . .at work today picking up a shift tomorrow.
So my plan for the base of the brake is add some angle iron long ways and then a few braces under them, welded in and a plywood shelf. I'll probably give it a coat of fresh paint and get away from the red.
Edit: sorry, had a couple EMS calls ....
I figure a piece of plywood as the shelf once the shelf bracing welded in. This will give me a spot about 24"x48" to store any sheet metal or aluminum that I have. Little pieces are always a pain in the *** to store. This will be floor space already taken up.
