Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
I graduated HS in '85, so we're about the same vintage.
(and sorry about my slow reply...)
My shopvac had a hard life for the first decade, and I'm sure it was abused. I "donated" it to my Grandparents' place in '89 so it probably had water left in it many times.
@SilverJimmy showed off the filter bags (his look practically new).
I like your idea of using a band clamp instead.
I'm following along on your tiling project -- that box blade should make short work of the grading. You've got a pretty good set of attachments for your JD, ready for your retirement and moving to the farm.
Shop vac base needs washed to try to remove the rust...on the "to-do" list...not enough hours currently in the day nor days in week.
I'm going try to get back on the tiling tomorrow or Tuesday....been dry here so I hope I can get it finished. Then the backhoe comes off for grading.
N
NUTTSGT
I'd think about just covering the rust stains.
Would spray paint for plastic work?
But the base is like a rubber/plastic compound, so maybe Flex Seal would work better.
(maybe it's not such a great idea after all...)
Not sure. I have to break out the power washer later today, I will try it with some scrubbing to see what happens, maybe 5 minute fix ? If not, it'll be fine as is.
N
NUTTSGT
No pictures but I did check out the tiling project at my parents this morning. I put a rodent guard in the end of the solid pipe. I also took the axe and pole pruner. I cut back a bunch of low hanging limbs so the Sun hits the grass to further aid in future drying up. I must say, granted it hasn't rained for a week but the ground is drying out very nice.
I changed the oil/filter in the JD 2032R so it's ready to get back to work over there. I also shortened a pre-made 20' chain down to 13'.
I wanted to go fourteen feet but it wasn't going to easily fit in FEL chain holder. That's 4' longer than I had previously stowed away. 20260601_152752.jpg
RickP
Annapolis, MD
Giving the rest of it a quick wipe with Simple Green and it's good enough for me.
Looks almost like new!
N
NUTTSGT
Off and on, I have worked on a little project for work. Our 2005 KME Ladder Tower needs some reworking on the electronic side if things. Basically, upgrading the hardware for ladder controls.
I believe I showed these pics in the "pics from work" thread.
Some of the stuff no longer needed.
Mind you, I'm only providing a helping hand in this particular assignment.
N
NUTTSGT
We have a new display panel going into the operator station on the turntable. The old display fit inside the square hole. That's the sunshade sitting below.
The two placards to the left, rung lights and evacuation stay in place. But hey, take a picture to remember which wire goes where. 20260504_103404.jpg
Rung lights are blue clearance lights in the inside of the 100' ladder. Basically runway lights for nighttime or heavy smoke conditions.
Evacuation is a button for the air horn. We use a long air horn blast for interior crews to rapidly exit a burning structure, usually this means conditions have changed for the worse. Also known as the GTFO button.
In lieu of all those lights cut in the previous post, there's two displays going in. I did some modifications to that panel in my garage.
N
NUTTSGT
So, this is where we're at now. I had to cut the panel anyway. A new load limit placard is getting made. 20260601_192845.jpg
Sitting in the hole is the wood template I built for mock up. I go back to work tomorrow and I'll see how it fits with the actual display module.
I think some trimming will be required as I believe the back edge has a taper on it.20260601_192854.jpg
N
NUTTSGT
I’m a little surprised they let you work on the rig like that. That was taboo in our department. We didn’t touch anything anything. If There’s a problem bring it to the shop lol. Although most of the time the rig would disappear for a long time when that happened.
nice work!!
Well for starters, the chief himself is doing the work. He also worked for KME on the side as a field tech and was a mechanic in a former life. The Ladder Tower will also go through annual ladder testing once it's back in operation. We try to work on what we can as we have no dedicated FD mechanic for the city. . . No fire apparatus shop.
N
NUTTSGT
I noticed a couple of weeks ago that the shed door was having an issue. The coil stock that I wrapped the door with at the bottom was dragging on the concrete. After some investigations, I found out that the wood inside had rotted.
Today was the day to fix it or so I thought. This is what found after some trim removal. 20260602_123428.jpg
XJSuperman
Central Iowa
I think theres one over in Twinsburg, but I can't speak for their work or anything like that. It just seems to come to mind that one setup shop there in an old truck repair place years ago. Then again, I could completely be mis-remembering that.
N
NUTTSGT
How close to the ground did the old door sit? I know you just poured that pad in front of the door in thr past 6 months.
Wasn’t it just bricks before?
Yes, just bricks and poured the pad a few months ago. It sits close but I think it should have been fine...I believe the issue was wrapping the entire bottom with coil stock, which allowed it to hold water. Since it couldn't dry out, it made a nice haven for insects.
N
NUTTSGT
If you remember how wet it was when I started the tiling project at my parents, this is what I started with....as previously seen
This is where it's at now.
I don't ever remember this spot being this dry during an average day. There's a 4" tile under the river rock and I'm extremely happy with how it's working out.
There's still some more work to do at my parents, what i would call fine tuning.... see how it all works out after rain and make some adjustments. I also need to do some brush clean up along the entire frontage.
N
NUTTSGT
A couple little projects that I'm try to get done with the little time I seem to have. So the first thing yesterday was some running to catch up. First stop, get some steel for a couple more shelves on the metal rack, grab breakfast and on to Menards. I picked up a wood top for the 56" box on order from HF.
I know it's hard to believe I need another one but all the machine tooling I bought last fall is just sitting there. I have to sort through it and need a place for it. The last 56" box became fastener storage and other storage.
I'll be cutting the top down to size and getting some type of finish on it.20260624_202909.jpg
rharman
SoCal
< snip >
< /snip >
I have that same miter saw stand. How do you like it?
I've been happy with mine. The only drawback is it doesn't have stops for length. The non-hydraulic version has flip-up stops or you can get them as an option. No such thing for the hydraulic stand version.
I keep thinking about fabbing something up but never had the urgency.
Here's the option for the other stands.
N
NUTTSGT
The little bit I have used it, I like it. I actually bought the saw (Christmas gift from wife) to cut rafters on the garage addition.
However, since I have it, I have it and won't be getting rid of it.
N
NUTTSGT
Since I replaced the shed door, the new one sits a tad bit higher. This created a larger gap than before a when mowing, grass is getting blown inside.
So during Amazon Prime days, I ordered a door sweep for it and got like 40% off. Its 48" long so it needs a slight trim.
Closing the door behind me allowed to screw the new sweep in about where I wanted it. I also added a short cut off section vertically to close up that door gap.
N
NUTTSGT
Another quick project for the station. A simple piece of 1/2" plywood cut to size for under a keyboard that sits too flat.
Then to the 10ga metal sheets I got at the local machine shop last week.
One went to the bottom of the metal rack to store the lathe jaws on. I won't be using these jaws, they were part of an auction win. I just need to list them somewhere. 20260629_151945.jpg
N
NUTTSGT
Then another quick project or a start of one. The plan is to build another cart for the box blade...the one I bought and have not had a chance to use. There's just enough days in the week right now.
Starting with a set of HF movers dollies, which in my book, are one if the best buys in the store.
I cut some 3/4" plywood to fill the centers.
20260629_154517.jpg ....up next, drill some pilots holes and screw them down.
These will, in the near future, will get a couple of 2x4s screwed for a place for the box blade to sit on.
In case you're wondering, here's the measurements I used.
RickP
Annapolis, MD
Those HF dollies are great -- I find myself using them all the time.
I like your idea for a box blade cart -- I just made a similar one to fit inside the base of my engine hoist. It's compact enough that it only uses one of the larger HF dollies.
bugnut
Central Ohio
Eric, I love those dollys. I have about a dozen. Use them constantly and they take the abuse. Recently supported four corners of a pallet so I could load the pallet and move anywhere I wanted. Set the beetle wheels on it and they go anywhere. I even disassemble them to put the caster on other things. Great buy indeed!
N
NUTTSGT
I made a similar one that the grapple for the FEL on the JD stores on. Damn handy to move it around and out of the way.
