Experience with equipment skates?
Smilodon
Titusville, FL
I looked, but couldn't find anything about this. Maybe also called something other than "skates".
I need to move some heavy(ish) stuff around a shop and have had good luck in the furniture realm with "skates". But, the furniture ones I have aren't heavy duty enough for shop use. This is for stand mounted equipment, boxes of heavy stuff and the like that are "light" enough to hand lift one end, so not too awful difficult to get on the skates.
Looking around, I see many, but was wondering if there were ones that folks have used on here with good success. Price is a consideration, as I probably will use them for a reorg or two, not daily.
I could live with the "metal roller" type, but would prefer something omnidirectional (the price goes up on those).
For reference, this is the kind of thing I'm talking about. These are the common "metal roller" type, one of many I've seen on Amazon. But, no way to know what is total garbage to be honest. So, I'm looking for some real world experience.
The Cobbler
something like this ?
Rusted Nut
Northern Arizona
Search “machinery rollers”. I’ve used these to move large building electrical gear and transformers, industrial machinery, and the like. Might be a bit spendy for a home shop though. I have a couple of cheap furniture dollies that work for a lot of garage items.
Cruzan80
Denver, CO
Hillman is the original. I just scored a set of 2T skates (8T total) for cheap on FBMP (less than new Vevor). This just esems like one of those things you dont want to cheap out on, when moving heavy equipment.
Stuart in MN
Minneapolis
I have a set of car skates, those things with casters you put under the tires so you can push the car around. The difficult part is getting all the casters pointed in the direction you want to go, once that's done it's not difficult for one man to move a 4,000 pound car.
I imagine equipment casters have the same issue.
whateg01
doo dah, kansas, usa
Pretty sure the ones Tom Lipton used were cheap ones from Amazon. I'm not sure that any of those really can be a bad choice. They are basically deep groove ball bearings on a frame or something equivalent to pallet jack wheels. Either way, not much to them.
OccupantRJ
Eastern North Carolina
What gorilla said, with emphasis, and I don't even consider using the machinery skates I have on hand until the load is in the multi-ton level. They are also pretty expensive. Anything that I can lift one end with a pry bar gets a 4 wheel dolly or a two wheel hand truck. A proper furniture cart, two or four wheel with strap can move a lot of awkward stuff. Big boy items with proper underneath access get a pallet jack or fork lift. Are the furniture skates you have extra light duty? Any that would move a tanker desk should move the average level workshop equipment. You also need one of these shithooks below. Thank me later.
matt_i
SE Michigan
EZ button is a pallet jack, just keep your stuff on pallets or build skids based on 2x4 "on edge". Then everything is quickly mobile and you don't have to horse on and off the skates. The front wheels of the pallet jack are very close cousins to those skates pictured.
In the machinery world I've used metal-tracked skates (Multiton) where the machine would only fit lengthwise into the shop, but these were machines weighing ~ (8000, 13,000 and 15,500) lbs. The steel wheeled "tank tracks" are hard on any concrete floor coating and so the "soft" pallet jack wheels are preferred at that point, just more wheels are employed to distribute the load.
The steel tracks have great capacity, I acquired a set which is rated 30k "per skate" for a sum total of 120k. Likely more capacity than I will ever need.
Edit: Gorilla said this and I skimmed over...but to reiterate......Beware when using skates that 3 is the best starting point. 3 points define a plane and so the load won't tip ever. But with 4 skates there can come a point where one is no longer carrying any load and is left behind. This makes for a puckery or scrambley moment where it looks like the object is going to crash back to earth. If you come across that, I stuff a wad of paper towel or cardboard or kraft paper under the offender to keep it dragging along even if the vertical load goes to zero temporarily.
S
Smilodon
Titusville, FL
(Sorry, long response, just trying to explain what I was looking for in this thread)
I'm rearranging a shop that I inherited. So, the usages are varied. Generally moving stuff on a concrete floor, so "off-road" wheels not really required. Would like ones as low profile as possible. The snow-mobile things look interesting, but I'm a little concerned at their relative height.
Pallet jack isn't exactly what I'm looking for. While it would be nice to have one, they take up space (that I'm trying to free up by moving stuff) and many of the moves are in very tight spaces. As a result of this, something that was more multi-directional than the "roller" type would be nice. I know you can get the roller type to go around corners, but it's a lot of work.
I'm not constantly moving stuff, so not really looking for an on-going "system" of rolling stuff around the shop. This is kind of a one-off. Not a shop where I'm working on heavy stuff all the time (looking at you @zkdiesel :)) and need everything stored in such a way that it can be equipment moved.
The house in my inherited property was first and a bunch of furniture had to be moved. It was just my wife and I, so we got pretty good at using the furniture-grade "skis" (stamped sheet metal with three wheels). Ended up having to buy some better versions of those with ball bearings rather than bushings. So, have some familiarity with working with them in a lighter weight format.
I have regular wooden dollies of various sizes and shapes. They always tend to be the wrong size for whatever I'm moving and the wheels on mine are generally not up to something like a bandsaw on a stand or loaded toolbox. I could get heavier-duty standard dollies, but could never get a size that works with everything. Discovered this with different size, legged furniture and that's how I ended up with the skis for those to begin with.
When I look on the appropriate sites, I find a huge array of prices, types, etc. I'm pretty sure "skis" are what I want, but I guess I was more looking for here was some way to narrow things down to a good price/performance point. And get steered away from stuff that doesn't work well. Not looking to totally cheap out, but don't need "Snap On" equivalent either. They are probably going to sit on a shelf a lot once I get the shop arranged.
I mean, is Venvor generally good enough for temporary use? They have both of the common types I've seen.
Roller Type 61VIo6ydS7L._AC_UL232_SR232,232_.jpg - "Pentagon" Type 51qmfV45EAL._AC_UL232_SR232,232_.jpg
Also found some one-offs with ball rollers that look interesting, but tough to spring for them with no experience.
PS: How do I include the atomic partner stuff in the Amazon links?
Stuart in MN
Minneapolis
The cheap small furniture dollies from Harbor Freight or other places (Menards sells them, for example) can handle a surprising amount of weight. When you have three or four of them of course the load capacity increases. You do have to be able to lift up the thing you're trying to move enough to slip them underneath.
I have a motorcycle right now that's sitting on a single one of them, I imagine it weighs 250 pounds or more.
Edit: I just looked at the HF website, their 18" x 12" dolly is rated for 1000 lbs.
carlaisle
If you can hand lift one end, you're solidly in the sub-500ish lb category. I've moved tons of things with some no-name dollies probably not much better in quality than these: https://www.ebay.com/itm/137016980229. Biggest problem is the tiny wheels react to a zip tie like a wheel chock. If the potential to lose control of the load upon loss of a dolly is a concern, use a ratchet strap or other means of temporary positive attachment to ensure that doesn't happen.
