It is marked "R97" near the hang hole on the side showing.The top one looks to be the Danielson design, probably after being bought out by the Plombpire. Maybe 1957?
How do you fix that one?
Little bit of abrasive maintenance on the screw shank?Long soak in Evaporust in an USC.
@d42jeepDon,
I just got this in. It's a Indestro Super Quality box with D-I sockets and the #2850 flex handle. The box is 9 3/4 × 3 1/4 so similar to your Duro blue box but this one appears more OD green (and Indestro). Not seeing it in the 1935 catalog so unsure what's supposed to be stocked in it. Have ya seen this one before?
Yep, I believe this to be a 1948 3/8dr #2700 set. The sockets up to 5/8" fit just fine. The remaining two sockets, 11/16 & 3/4 must have been somewhat slimmer because the one 3/4" 2724 socket I have doesn't fit. The pictures in the 1948 catalog illustrates them differently too. My 9" 2781 breaker flex bar fits fine too. So I took the D-I 1/4dr sockets out and placed them into a Duro D-I appropriate box. Now to locate the rest of the missing sockets, a 2788 ratchet with the 1" adapter and a 4-inch double male extension...or it may simply become a #2701 set.@d42jeep
@four.cycle
The more I look at this I'm thinking this may be a #2701 3/8drive set. It's 9 1/2" wide and 3" deep. The D-I 1/4 drive sockets and flex handle that came with it may just be misplaced. Gonna see if I can find some 1948 3/8 drive 2700 series sockets and see how they fit...
This may be the same box made by Indestro for Western Auto.Yep, I believe this to be a 1948 3/8dr #2700 set. The sockets up to 5/8" fit just fine. The remaining two sockets, 11/16 & 3/4 must have been somewhat slimmer because the one 3/4" 2724 socket I have doesn't fit. The pictures in the 1948 catalog illustrates them differently too. My 9" 2781 breaker flex bar fits fine too. So I took the D-I 1/4dr sockets out and placed them into a Duro D-I appropriate box. Now to locate the rest of the missing sockets, a 2788 ratchet with the 1" adapter and a 4-inch double male extension...or it may simply become a #2701 set.![]()
