neophyte
The term “Bronze” nowadays just means an alloy that is a majority copper, with alloying elements to improve strength and other material properties, although usually the major alloying element is specified, ie. “aluminum bronze” or “nickel bronze”.It appears you're right, and that would make sense.
Their English page says "gunmetal sandwich". Their Japanese page when fed through Google Translate does say "bronze". Looks like the brass misconception is pretty common in English everywhere online.
“Brass” is basically just “zinc bronze”.
Nomenclature wise though, the terms can get confusing when translated into other languages, because “Brass” and “Bronze” are older terminologies that have stuck around and wound up being used variously over centuries, and the terminology doesn’t always translate perfectly.
