Innovate1
Thinking an angle indicator would be useful. The type you stick on something (I think many are magnetic) and it indicates the angle from level. Digital readout.
Well I would say if it is accurate at a known angle, it is accurate at any angle. These things are supposedly good to .1 degree (6 minutes). The 30.5 was my way to see this. I'll try some randomly picked angles, but my shop was over 90, so I was done!
Interesting. I've never used it for that shallow an angle and whether I'd trust it at that. I'll do some more testing when it cools off a little.I dont disagree, but was more curious if there was "bias" to round once it is close to a "standard" angle. But the 30.5 probably countered that idea...
I also wasn't sure how "low" it could read reliably (say in the 1.5-4deg range).
It would be interesting to see the same test using the iphone app.Just for kicks, I broke out my sine bar and gauge blocks to see how accurate my cheap digital angle finder is.
Below is set for 45, 30 and 30.5 degrees:
The Shinwa looks like it could be in a movie. Functionally, it seems equivalent to a Johnson magnetic angle locator. Made in USA, $11 at Lowe's, lacking all the refinement of the Shinwa.Does it have to be digital?
