Shed insulation determination
HomeNovice
IMG_2661.jpegI’m trying to determine if there is any ventilation at the top of my shed. I plan on using this as a three season room in NJ and, as a novice, I am unsure the next steps.
I apologize if my vocabulary is off! My plan was to install baffles to allow the air flow from the soffit to the ridge peak, cover with rockwool, and finish with some kind of tongue and grove. I’d probably stain the wood that would be exposed. However, the black between the opening feels like pretty tight foam, and I’m not putting in any ventilation/cutting through the metal roof to do this. I’m not looking to spray foam it either, but if it is totally closed at the peak, is that my only option if I want to insulate the ceiling?
Images attached
jack stand
Lakes Region Maine
The easiest way to check to see if the ridge is vented without hacking up the inside would be to take a piece of ridge off.
Those ridge caps usually will allow for some ventilation but require the correct closures to keep the weather (blowing snow) out.
How big is this shed?
H
HomeNovice
The inside of the shed area is about 9.5x8.5. I called the manufacturer, no reply or call back as of yet
