Residential electrical switch box covers: why not Phillips?
mm08822
I had one customer tell me as I finished up that he wanted all the screw slots vertical.....hahaha.....yup...funny
HE WAS SERIOUS!!! Im sure the expression on my face was more than insulting 🤐
mm08822
Allen heads for the win 🏆
ETA: Even double hex for those still confounded with a simple hex.
rlitman
Long Island
I own a number of those screw starters, but for plate screws, I use a Wera insulated parallel ground slotted screwdriver that fits so perfectly that it will hang it's own weight from the screw if it's roughly horizontal.
Codyboy
S.E. TEXAS
Why do residential switch plate cover plates use straight slot screws instead of Phillips? Is it to avoid overtorqueing?
Actually more torque can be applied with a *slotted screw as compared to a Phillips.
*with a proper fitting screwdriver.
ETA
Switch plates get vertical while receptacles get horizontal.
this is non negotiable .
Gozo
Central VA
Codyboy said: Switch plates get vertical while receptacles get horizontal.
this is non negotiable.
Great…another thing to keep me up at night.
I’m a vertical fan myself, but on the outlets, if they’re mounted vertically, they follow my preference for the slot vertical. I’ve got a few double outlets mounted horizontally; I’ll have to check how the screws are. Ditto the Christmas tree floor outlet. So parallel or opposed to the axis of the outlet slots?
MacMcMacmac
canada
Maybe the slotted drivers slip out enough times that the person turning the screw says" Effit, good enough!" long before it gets overtorqued.
dscheidt
Of course he was serious. I'd expect the same thing, and not have to ask for it. It's how it's been done for 100 years.
Meursault74
Southern California
slotted so you can work on it with a butter knife and save a trip to the garage when you're working in the kitchen. :LOL:
not that I'd use a butterknife............. I keep a multi-bit screwdriver in the kitchen utility drawer like every good GJ member should.
rmanrman
I’ve had customers congratulate me for the screw orientation horizontal. Aka as left to right
Electricians are special
Stuart in MN
Minneapolis
I suspect a little bit of it is they've been making the covers forever with slotted screws, and there was little reason to change.
The screws are small enough that you'd probably need a #0 or #1 Phillips screwdriver, and most people don't have either one.
Stuart in MN
Minneapolis
It's like the toilet paper roll argument going on currently in another discussion, there's no one answer. I like the screws to be installed with the slots horizontal so that's how they are in my house. I don't care if other people like them vertical.
johnre
Portland, OR
Now I understand why screwless plates exist. It's to help those with a few loose screws hide the real concern......
Whoa, hitting pretty close to home - I have Lutron Fassada screwless plates, for this exact reason.
OK, I'll give you that. But you have to tell us once and for all which way the grounding pin goes on a NEMA 5-15R receptacle. :devilish: :devilish: :devilish:
Codyboy
S.E. TEXAS
Ground pin down.
It acts like a stiff leg to support the cord.
Also look at how a refrigerator cord is made.
yatg
Southern Oregon
Ground pin down.
not consistently. i have a garage fridge and freezer. on one the cord hangs from the ground pin end, on the other the cord hangs from the hot/neut blade end. i have a 2g box with one recept ground pin down, and the other ground pin up to keep the cord hanging down and not bending over iteself.
kbuhagiar
Escondido, CA
Electricians here in San Diego County seem to favor installing all new outlets with ground pin UP. I don't know if it's required or if it's just a local practice.
I questioned this during the construction of my garage addition (all of the outlets had been installed with the writing upside-down and I brought this to the contractor's attention), and I was told the theory is, if a plug isn't fully inserted, an object falling onto the plug would contact the ground pin first, as opposed to the live conductors.
I guess I could buy into that, but I did sort of mentally roll my eyes, then I took a deep breath and told my OCD self to calm down. :LOL:
bwringer
Indianapolis
I swear upon all that is holy that I oriented all the screws vertically about six years ago when I replaced every last outlet and switch in my house. (They were all backstabbed by the lazy a-holes who wired this place, and several were arcing, overheating and generally trying to kill us in our sleep.)
Anyway, I have no idea what slow force might be acting on the screws, but several are... moving. Some are now up to 15 degrees off kilter. I suppose I'll have to go around with a screwdriver soon, and meddle with the will of unseen forces I do not understand...
mm08822
Red lock-tite or drill out and use pop-rivets.
Dumber than lumber
I know someone who recently bought a house. All the faceplate screws were clocked into the 12:00 o'clock orientation.
