Residential electrical switch box covers: why not Phillips?
vavet
Ashland, VA
Why do residential switch plate cover plates use straight slot screws instead of Phillips? Is it to avoid overtorqueing?
tradition?
mm08822
I had one customer tell me as I finished up that he wanted all the screw slots vertical.....hahaha.....yup...funny
HE WAS SERIOUS!!! Im sure the expression on my face was more than insulting 🤐
mm08822
Allen heads for the win 🏆
ETA: Even double hex for those still confounded with a simple hex.
Codyboy
S.E. TEXAS
Actually more torque can be applied with a *slotted screw as compared to a Phillips.
*with a proper fitting screwdriver.
ETA
Switch plates get vertical while receptacles get horizontal.
this is non negotiable .
Gozo
Central VA
Codyboy said: Switch plates get vertical while receptacles get horizontal.
this is non negotiable.
Great…another thing to keep me up at night.
I’m a vertical fan myself, but on the outlets, if they’re mounted vertically, they follow my preference for the slot vertical. I’ve got a few double outlets mounted horizontally; I’ll have to check how the screws are. Ditto the Christmas tree floor outlet. So parallel or opposed to the axis of the outlet slots?
MacMcMacmac
canada
Maybe the slotted drivers slip out enough times that the person turning the screw says" Effit, good enough!" long before it gets overtorqued.
dscheidt
Of course he was serious. I'd expect the same thing, and not have to ask for it. It's how it's been done for 100 years.
Meursault74
Southern California
slotted so you can work on it with a butter knife and save a trip to the garage when you're working in the kitchen. :LOL:
not that I'd use a butterknife............. I keep a multi-bit screwdriver in the kitchen utility drawer like every good GJ member should.
rmanrman
I’ve had customers congratulate me for the screw orientation horizontal. Aka as left to right
Electricians are special
Stuart in MN
Minneapolis
I suspect a little bit of it is they've been making the covers forever with slotted screws, and there was little reason to change.
The screws are small enough that you'd probably need a #0 or #1 Phillips screwdriver, and most people don't have either one.
Stuart in MN
Minneapolis
It's like the toilet paper roll argument going on currently in another discussion, there's no one answer. I like the screws to be installed with the slots horizontal so that's how they are in my house. I don't care if other people like them vertical.
johnre
Portland, OR
Now I understand why screwless plates exist. It's to help those with a few loose screws hide the real concern......
Whoa, hitting pretty close to home - I have Lutron Fassada screwless plates, for this exact reason.
OK, I'll give you that. But you have to tell us once and for all which way the grounding pin goes on a NEMA 5-15R receptacle. :devilish: :devilish: :devilish:
