Show your new tool arrivals
YesIHaveAHammer
Klein LAN Scout® Jr. 2 ethernet cable tester VDV526-200
On its own, it verifies the cable and displays the detail of any fault/mistake. It can also generate tones for tracing cables with a separately available probe. The short patch cables were separate, essential for testing installed sockets end to end. The range includes one more basic and two more advanced ones.
Facom 441 XL OGV Grip wrenches 11, 12mm
Filling out more of that partial set I got cheap.
Facom 41 Offset Combination Wrench 13mm
Just trying something a little different.
Saltus 3=1 swivel socket combination wrench 15mm
Filling a gap in my set. They're rarely available now so I figured it's my only chance.
ETJ
Used Snap-on EEPV508 transmission and engine pressure set
Unused 2nd hand Blue-point (RIDGID) E1025 extractor set. Only paid 55 euros compared to the silly list price of $1220.IMG_1485.jpg
Used Snapon sockets:
- 208EFAY SAE standard hex bit socket set
- 206EFABL SAE long ball hex bit socket set
-206EFAL SAE long hex bit socket set
-206EFAML Metric long hex bit socket set
-Older 9-piece BEXD deep extractor socket set
-Two low profile spark plug sockets
Snap-on SAE line wrench set RXFS605B.
Lisle small hose clamp vise and filter wrench.
Bahco filter wrench.
Snap-on REX25C Multispline screw extractor set and EXD10 screw extractor and drill bit set.
Bahco brake line tools
and couple deburring tools
mikeinri
Some seriously valuable wisdom here...
It can be best for DIY use to have a USA Vermont American quality level set covering most occasional needs and eventualities and replace specific sizes in that set that you use a lot with higher quality ones. Then you do not break the bank to cover stuff you only use a little, have good coverage for what might come up from time to time, and also have good ones for the sizes that you use a lot.
By the way, some of the people showing tap and die pics should oil + clean them more before storage. When they rust, it degrades the cutting edges. I try to wipe mine down with something like WD-40 after use and then store them somewhere dry. Surface rust will mess up a good quality top or die and it is much easier to prevent than to try and address it or resharpen after it starts rusting. It is also not a good idea to let cutting oil and grime harden into a sludge on them. They usually clean up pretty easily if done right after use.
Mike
gilbo
I just got my USA made Irwin tap & die set from Menards.
I also got this set of press and pull sleeve. Made pressing in bushings a breeze for my suburban
I also got a couple fluid extractors. The Four Uncles pneumatic/manual makes changing ATF a lot less messy. I just used this week to drop the pan on my OBS C1500, so much quicker and easier, but mainly no mess. If you don't have one get one.
The OMT fluid extractor will be great when changing brake and P/S fluid.
AJHD
Was this recent? Have a link and price?
I passed on the Icon sets this weekend at 20% off. Unfortunately actual USA made kits are ceasing to exist and in a hurry.
