New Icon Bigger Meme Tool
BWWgarage
After some household use, I’ve made another revision to my kit. I modified the box by cutting out the cradle for the spinner handle, then either added the following items to supplement the kit or replaced existing items with these.
Surprisingly, the box still closes. :)
  • 711L Mini Bit Ratchet
  • Robertson Bits (SQ1, SQ2, SQ3)
  • 1/4” Hex to 4mm MicroBit Adapter
  • Coin Driver Bit
  • Wing Nut Driver Bit
  • T3–T8 4mm Bits
  • Facom ECR.1 1/4” Hex to 1/4” Square Adapter
  • Facom R.254 1/4” Drive 1/4” Hex Bit Holder
  • USAG R.180 Compact Ratchet (237 SKF D) and Extension (236 SKF D) for 1/4” Bits
  • Bahco 100mm / 4” 8069 Adjustable Wrench
  • 711L Lollipop Bit Driver
  • 711L 1/4” Magnetic Bit Extension / T-Handle / L-Handle
  • Snap-on LN44BCFND 5” Talon Grip Long-Nose Slip-Joint Pliers (No Dip)
  • Icon G2 R1XS 1/4” Short Ratchet
  • Koken 2120 1/4” Drive Magnetic Head Magnet
  • Olight i1R 2 EOS Keychain Flashlight
That is pretty complete, compact kit!
