Vintage RIDGID Pipe Wrenches
SwampFox2190
Charleston, SC
Thank you, Sir. I will look into the spring assembly and report back.
I also picked up this 14" via EBay on Friday night after a few beers... Too clean to pass up for the price. Looks to me to have older identifiers in the sqaured jaw , black coating/lack of paint, and patent #. But the ring would indicate 1948+, unless it was swapped out at some point. Date code from what I can see from the photo (I don't have it in hand yet) reads B37, which I am somewhere in between putting this one at 1947 or 1957. Either way, looks to be in almost new condition and I don't have any older models w/ the warranty decal still intact. It will get use just as the rest do!
MRL83
Thanks and welcome to GJ!
That's the only prerequisite there is for enjoying this forum! :)
Cool. When you start diving into other topics, note that there is an A-Z Index of Threads in the Sticky at the top of the forum that essentially negates the tyranny of the forum's descending chronology.
Yes. Well done. :thumbup:
Good question and one I don't know the answer to. They experimented with so many different mechanisms over the years, I'm tempted to guess not. If you live near a good flea market, cannibalizing one from a donor of the same time period is a good option.
Long time follower, first time contributor. I have thoroughly enjoyed reading this thread in its entirety!
Been a gatherer/user of old tools my whole life and recently dove into old Ridgids. Picked up this E10 offset a few weeks back for my daily use bag, beautiful patina and in great shape overall. Put it back to use day of delivery after I assume was a lengthy sabatical from turning pipe.
After reading through the whole thread, am I correct in assuming the date code B93 and identifiers would put this one at 1953? Also, it is missing the internal spring assembly. Are the current factory parts compatible w/ the older models? Still grips just fine, but a decent amount of play in the dynamic jaw and handle body. Offset 1.jpg
SwampFox, to answer your question about current factory parts being compatible with older wrenches, it’s been my experience that new springs, jaws, rings are all compatible with even the oldest wrenches. And a lot of those parts are available on eBay, usually for a few bucks. (I have quite an embarrassment of “riches” due to countless hours getting lost and carried away trolling eBay.)
Just make sure you get a spring set for a straight or angled wrench. Most people (myself included), refer to an angled wrench as an “offset” wrench, where as RIDGID’s definition of offset is the wrench where the dynamic jaw goes through the handle at 90*.
Straight and angled wrenches use the same spring, an “offset” spring will only fit an offset wrench.
Hope that helps some, good luck!
SwampFox2190
Charleston, SC
Two 6"s I recently picked up. Am I correct in dating the older one to 1942 via the stamp on the jaw B-4-2?
P
Yes.
The photo is also a great illustration of the next generation and the feature differences. Red finish (vs. Black or none), rounded off end of dynamic jaw (vs. squared off end), the recess in the middle of the adjusting nut (vs. Fully knurled). But note how identical the overall profile and shape are, except for the slight flare around the hanging hole), static jaw/handle, housing, trademarked swashplate, etc.
Ridgid 18 in pipe wrench (patent 1727623)(code A6-2) 05/11/26 (after removal from evaporust bath)
Ridgid 18 in pipe wrench (patent 1727623)(code A6-2) 05/12/26
Nice 1942 18” example.
It was heavily rusted. To the point it sat in the Evaporust for well over a week.
You all did notice the traces of black paint, right? :unsure:
Even after all the wire-wheeling, there's still a few specks of black paint in the hanger hole.
At @RTM's suggestion, I cut the BLO with turpentine, rubbed it on, and then wiped it down after several hours. Dried overnight. Looks great.
emp98
Hoping I’m not commenting into the void of a 12 yo thread, but I’m restoring some vintage pipe wrenches that seem by all accounts to be post 1950s, in body style, but one of them has the interlocking DG but with a rounded end. Guessing they started doing this again at some point but can’t find much online regarding it . Anyone have any info? (Note last photo of them taken apart includes a non ridgid pipe wrench, it was just a pic I took for before purposes so feel free to ignore that one)
P
If you scroll up on this page you will see activity in May and earlier in June of this year. Due to the endurance of the tools, and the enduring interest in them, this thread has never been dormant for very long.
I’m restoring some vintage pipe wrenches that seem by all accounts to be post 1950s, in body style, but one of them has the interlocking DG but with a rounded end. Guessing they started doing this again at some point...
Your query seems to be based on the premise that at some point in time the Ridge Tool Company stopped making pipe wrenches with an interlocking D and G in the RIDGID branding and I can see that you've included an example of one. I have no idea when that was, exactly, but I can assure you that it wasn't in the 1950's or 1960's.
While this thread was primarily focused on the date codes found on wartime pipe wrenches and mainly includes examples of pre-war and wartime pipe wrenches, many examples of 1950's and later pipe wrenches have been posted, and they all have interlocking D and G branding on the frame and the dynamic jaw. If you look through Ridge catalogs in the Internet Archive International Hand Tool Catalog, you will find many catalogs from the 1950's and 1960's, all showing wrenches with interlocking D and G branding.
1967
1961
1956
P
Curious, even though I don't collect tools from later eras, I did look through catalogs a little later than 1967, and it didn't take me long to discover that they seemed to have gone to branding and production of wrenches with a connected (but not interlocking) D and G sometime between 1967 and 1973.
1973
It seems like none of my conventional aluminum pipe wrenches have the interlocking D and G.IMG_8873.jpegIMG_8495.jpeg
On the other hand, this aluminum wrench has the interlocking letters.IMG_3815.jpegIMG_2728.jpeg
P
^ I don't collect them, and I don't know when Ridge introduced aluminum composition wrenches, Don, and I didn't have enough interest to check all styles of wrenches when I was inside those '67 and '73 catalogs, but, I suspect that if they were going to make a branding change of that magnitude - interlocking D and G to merged or connected D and G - that they would do it across all wrenches and all tools. I'd be surprised if they didn't. It would be easy enough for someone to confirm.
GreenMars
Hello fellow tool enthusiasts! I picked a 14" at the habit for humanity store and I was trying to figure out the approximate year based on the info in this thread, but the jaw code is only "A1" and says patent pending. Mr. Lugnutz, you have been at this a long time, shouldn't you have been promoted to General by now? :). What is your best guess on this one?
P
Snerk. Too many Article 15's! :)
No guessing required. It's very clear. Those PAT PEND'G wrenches were made between January 11, 1928 and October 10, 1929.
See post #1 for more...
The next definitive generation RIDGID pipe wrench has the stabilizer (4) and the trapezoidal swash plate (5), as shown in the second patent drawing, but reads "PAT PEND'G" on the handle (6). That suggests that the second patent (1,727,623) had been applied for (on January 11, 1928), but not yet granted.
RIDGID pipe wrenches with "PAT'D" in that spot (6) or the forged-in patent number "1,727,623" in that spot (7) could not have been made before the patent was granted, on 9/10/1929.
