Mystery Snap-on Tool Of The Day
Skyline
Marked MT150
Date coded 1982
Industrial Finish
snapmom
Florida
Snap on N6700
snapmom
Florida
No, not holes for springs. The model number N , its a specialty tool, special made for a industry purpose, I do not know the use, hoping someone did.
Junkman
Northeastern CT
It is a birth defect that happens in 1 out of 10 million births of pliers. I believe that there is a hospital in Texas that specializes in separating the conjoined twin pliers. The surgery isn't going to be cheap, however, if successful, those pliers will go on to live a normal and productive life in society. Their life expectancy should be that of a regular pliers....
:lol_hitti
S
Skyline
that would be too easy........MT is usually for test equipment.
skyline, is it a square tip? maybe a double d for CCC carbs?
No, sorry I could not get a better picture. It has a long flat tip that is pointed on the end...but not too sharp. Every see those flat drill bits that combine a countersink and a section for the non-threaded part of a screw? Well it's kind of a tip like that but not sharp.
zuspiel
Houston, TX
:lol_hitti
My thoughts, exactly. :) :) :)
Uncle Buck
Kansas
Sorry for the bad picture...but it's not square at all on the end. Here's a better picture:
Looks like the one end has a 1/4" drive recess, and the other end is a bit for drilling and countersinking wood screws, or perhaps sheetmetal.
S
Skyline
hholmberg
You're right on the 1/4" drive, but the business end is not sharp at all.
garfunkle24
Saskatoon, Canada
Krusty
How much receiving depth does that socket have, like a couple of mm?
Edit: I'm gonna say it's for getting nuts started when you can't get a hand on them.
ps that socket is 30 years older than me.
S
Skyline
They do still make magnetic sockets...I think that's just an older part number of something still made today.
bchee
Texas
Thanks! My adolescence coinciding with the establishment and subsequent blossoming of the internet left me with formidable googling talents, particularly for the search term 'hole'....:bounce:
some holes are hard to find. Just be persistent.
snapmom
Florida
the 9473 is probably a drain plug socket. If its a 11/16 its for a Hudson , used to hold and turn the drain plug on fluid clutches.
55Savoy
Stead AFB
Here we go, want is this one use for? Snap-on H-1120 SSP. USA date code of Z
snapmom
Florida
Its a socket that fits into a sledge boxocket , converting the wrench into a sledge socket, they made them in sizes 1-5/8 to 4-5/8.
