Heck, its not that hard to miss something and be disappointed when they are bare steel and rust..
If one buys enough vises and is not leery and does not carefully scrutinize the paint etc, it is only a matter of time to be disappointed!
gman, I must admit my post reads as ambiguous. What I meant by not being disappointed was that there is always something under the paint that I don't like!
Is there a place to get replacement jaws for a Superior #3? Maybe a handle too? Dr. Scott - do you have a website?
Thanks - I’ll take measurements when I get home and send you a PM. It’s funny that I had both of those sites already bookmarked.Sorry, no Superior jaws on either of my websites. If you post or PM me with jaw spec:s maybe I have something close that can be modified. Websites are listed in my signature View Public Profile.
I found brazing to be much easier than I thought it would (could) be. I watched 12 (or more) videos on brazing before doing anything. Then I practiced on a couple of cast pipe fittings.
Finally I brazed up my repair, and I could not be happier with the result.
I think you should try brazing... If I can do it pretty much anyone can.
Hey guys, I could use some advice.
I found this very nice Craftsman 5176 locally. I intend to clean it up and resell it, just to put all of my cards on the table here.
While it is in very good condition, it has been sitting around in a garage and so it is rusty on the bare steel.
I would normally take apart a vise and use a small electrolysis tank to remove the rust, HOWEVER... I believe that will not be great for (what I think is the original) the paint, right?
And... what will that do to the badge? If it's going to damage the badge I don't have to use the electrolysis... What else can/should I use?
Or should I just remove the badge, and completely strip and repaint it?
Thanks,
Steve
How do you get the spindle out of a reed vise - specifically the 103-1/2R but thy all look the same. There's a set screw on the side which I removed and it looks like another flat blade type screw head underneath but the slot - if it is a slot - is too shallow to engage a screwdriver. The spindle seems to have a sort of castellated collar which I assume is locked by whatever this set screw arrangement is.
^ I would, probably cut down on wear from the screw rubbing on the dynamic jaw.
do not want a foreign screw thanks
I applaud and appreciate others like me who will not accept this foreign low quality junk. I have a 614 athol need center screw, will any other screws fit do not want a foreign screw thanks
Does anybody have one of the fancy cast iron wingnuts for the post under this vise? It’s a Reed 31. I have the mounting post, not pictured, it’s 3/4-10 thread size.
I rescued this vise from a dumpster in my neighborhood. It was rusty and seized. This was my first “soak the whole thing in Evaporust” project. After soaking, scrubbing clean under running water with a small brass wire brush, I dried it off with a heat gun. Then I rubbed on a very thin coat of flat paint followed by BLO. No paint on the swivel base, the handle, or the slide.
I highlighted the lettering by sanding with a sanding sponge exposing fresh metal.
Shift, one of these might work? https://www.mcmaster.com/6422k49
JP Smith: thanks for the tip and i'm assuming inside a blast cabinet or do you do that with a gun out in the yard with a tarp down? either way probably works and may just depend if you want to keep your product after you are done for the next time you need some. i'm also going to add sandblasting until i hear it might beat up our old steel vises too much.
For media blasting either method will work, and media blasting will work fine to clean up an old vise, however you want to be carful with what media you use, as mentioned a ground glass could be used but it might scar/chip the casting on the
vise espically if it is already starting to chip in an area. I would suggest using a finer media like sand, a lot easier on the material, also i would not media blast machined parts/surfaces because it will ruin the surface finish. Also on a wilton bullet i would not blast the cap for fear of denting the sheet metal.
