timtim2008
Do automotive Lifts fail often?
(Or are improper operation more to blame)
One of the best safety habits I learned from HS auto shop was to lift the car about 6" and give it a good shove, up/down and sideways. It shouldn't move.
lift failures are very rare. Lift user errors less so.
this is common. We had a mechanic drop the car while not looking and crush his new Mac roll around. The car in the next bay was running and loud and this covered the sound until the roll around was abut 6 niches shorter. The roll round oil and coolant drains are fair game for vertical reductions too. The bowls end up looking like 1/2 of a torque converter.With the old in ground pneumatic over hydraulic racks, when they'd get some age on them, they could leak down over the course of the evening.
The classic "operator error" was leaving either a transmission jack or a five foot jack stand under the vehicle.
Surprise!
The next there would be a new topic of discussion over coffee and smokes.
WoD
What happened to the safety locks?!had a challenger lift break the chain , truck went PLOP
It is very important to make sure the safety locks work.
Ive seen 3 rotary lifts fail in the past 2 years. 2 in gound and 1 four post.
The 2 in grounds rusted out. The plastic pocket didnt leak, but condensation pooled up. essentially the 2 rams busted through the bottom of the posts. The new ones that were installed were more stout in that same area. The 2 big posts that you actually see are not the lifting rams, the posts are secured into a sleeve that keeps the rams vertical. The rams push the posts up.
The four post broke a cable. Im sure they have a life cycle, but how do you track that in a commercial shop?
I have also seen a user error. He was installing an engine. Had it low with a jack under the trans, rocking the engine to get it bolted up. One of the arms must have shifted because there was no weight on it. When he raised it all the way back up, the vehicle shifted, the arm came out and down she went.
Easy. Just look at the cables. Almost never will every strand of a cable fail at once. When you see wear; replace them.
wow, did that recently happen? looks like it was uploaded on you tube today
i am going to have to say ,this one looks like operator error to me.
