vintage lincoln lube cabinet restore
autoclassicnut
Montana
I am in the process of converting an old Lincoln lube cabinet I picked up to a oil drain catch for under my lift. Here are some pictures of the progress so far.
Before...
A
autoclassicnut
Montana
After...
D.J.
New Haven IL
Man that did turn out very nice almost too good to use under the vehicles dropping oil into.
A
autoclassicnut
Montana
Here's some updates... I made a small roll around base for the lube cabinet.
A
autoclassicnut
Montana
I had to make it removable and yet stable, thus the small tabs that the cabinet sets on.
Here's a view of the inside, I had to make 3 of the inside corners braces, as they were missing.
A
autoclassicnut
Montana
The top will have something like my old drain cart... I welded a piece of pipe to a large washer and will use the old gas station lamp shade to drain the oil into. (After of course painting it red.)
Still in the planning stages of how to fab the extending pipe for the "lamp shade funnel".
Amitygravel
Claremont Illinois
Check the music stores or pawn shops for a microphone stand. They are extendable and should be plenty sturdy. Look the mike clips over too they might be of use also.
Craig
Lou's Garage
Anderson, SC
Those were often bought as a matched pair. By that, I mean the grease gun like you have was paired with a similar looking oil drain. Your restoration is not too far off from the original version. The cover sat on a dolly, inside was a larger oil tank (around 16 gal. IIRC) with a drain spout in the bottom that ran outside the cover. Waste oil tanks were underground in those days so you just pulled it over the tank opening and drained. The drain funnel and telescopic tubing was held in place by the top cover and the tank was sealed to prevent spillage. Great Job!
Lou
A
autoclassicnut
Montana
Lou
Lou... you wouldn't happen to have a picture of the oil drain would you?
A
autoclassicnut
Montana
Finished it today... wish I had the small trim piece that goes around the outside even with the Lincoln badge.
I decided to make some mounts on the side to hold the telescoping tubing I had for it. then painted the lamp shade oil catch to match. Now on to my next project...
c/o say
Indiana
That turned out nice and also handy but you know some one is upset you repurposed that lamp shade. lol
Doxhog
Illinois
My lincoln lube cabinet
rarevair
Valley Center, KS
Hey autoclassicnut,
Looks fantastic, thanks for sharing.
Maybe your next project should be getting the brakes on that '38 fixed, when they lock up like that they are leaving nasty marks on your floor GRIN
A
autoclassicnut
Montana
Hey autoclassicnut,
It's a "39 standard" and my wife was asking abut them the other day.... I said it was the only place I can do that and not get a ticket...:thumbup:
