My "L" shape Garage build !
overkill 19
Red Deer, Alberta Canada
After fighting with the city for 2 years about hieght. I'm finally getting started. Walls should start tomorrow.
O
overkill 19
Who won?? Looking forward to more.
They did! I wanted 24 feet to the peak, for a loft. We have a bylaw that garage height may only be 14'9 to the peak. I got 18 feet, so a loft is out, not worth it for me. I went with scissor trusses. So lots of head room for a lift if I want. They gave me the sq footage I wanted so I geuss I won there! Basically the garage is three parts. The "shed" is8x14. The car part is 24x24 with 10 foot walls. The shop is 20x34 with 14 foot walls.
O
overkill 19
More walls today! Moving forward, no rain in sight so that part is great!
O
overkill 19
Been busy!
O
overkill 19
Framers done. Windows, skylights and man doors in.
O
overkill 19
Been busy! Decided to re-do the house roof while we were going!
Built my floor drain/ sump filter system for garage!
Siding is coming along!
O
overkill 19
Sorry I lost touch with this thread...switched to a Mac, busy with kid, and got allot older! Anyway here's a couple updates.
Trenching power cable and Internet lines.
Insulation done and rough in for vac.
some more framing pics, sorry I'm so out of sync
I keep finding pictures then trying to add them to the right spot all on my phone! Lol
Anyway you get drift
O
overkill 19
Ben the best concrete guy in Red Deer worked on my floor until 2am....trucks in back ally at 8:30 am.
He polished the chit out of it, worked the hardener in perfectly. Over and above my expectations. I can drop a hammer and it bounces.
O
overkill 19
Electrical budget was blown. It was my only real shock when it came to costs. I figured I'd spend $2500-$3000.....FAIL !
even the boy helped!
I was 3x that easy. I had planned on putting T5 lights up but after the wiring budget blown. I went with T8 from HD for now.
O
overkill 19
Drywall went up... I didn't take many pics while they were doing it... I couldn't stand to see my shiny floor all covered in drywall dust and mud.
All around the bottom of entire garage we put in the moisture barrier drywall...sorry I forget what they call it.
O
overkill 19
Temp Drain line!
Got drain line bent up for furnace.
For those who ask. I priced out in floor heating and it was going to be anywhere from $9000 to $17000 is the quotes I got. My father-inlaw has it. To be honest I don't like it in a garage. It's too hot, laying on floor for me. Plus I did my whole heat system for $1800,furnace,round vent pipe and metal gas line and fittings.
It blows hot air across cars and keeps shed at far end plenty warm. I have zero moisture problems. I keep the ceiling fans on low in the winter to keep air moving.. So far so good
O
overkill 19
So here's a mistake I made! I built this Allen block steps with pavers as a floor to be able to get to the main man door.
Then back filled dirt and sod around it. .... Hated it, it was just too hard to slope it to get good drainage and be able to land in shed door with in reason.
You can kind of see it in this pic, sorry it's all I could find.
Anyway! More work!
New style TREX
some goofy corners and beer time!
O
overkill 19
and the landing to the shed door
and around to back gate where we take garbage out.
One thing I'm soo glad I did... 48" man door to shed to get lawn mowers etc in-out with ease. Also notice all doors out swing.. Little less easy to break in. I should have took a pic but there is a 1/4" flat bar framed in where the dead bolt sets into. Should slow them down a little!
sidewalk
back gate with cool Handel me and my son made!
O
overkill 19
Here's my inspiration for the wiring!! This is my brothers house!!
and some of the rest of the mech room
He also upped me bad on the garage work bench dept!!! A DSW custom...it's like $600 a foot! Nice but mine gets used too much!
boobag
wow, looks nice. and i like how you gave the garage a lot of detail, and not just make a cookie cutter garage.
O
overkill 19
Looks great. What was your final floor finishing?
Sent from my Passport
I just put Color mixed into concrete then he polished and polished!, it was coldish..when we poured so after he was done he put a lot of sealed on knowing it would flake off and turn white. He was just trying to slow the moisture from coming out too fast. So I have just left it and this summer I'll rent a polisher/scrubber to take off the bad sealer and re do it. It should come out gun metal ish from the pieces I've tried.
O
overkill 19
Thx
I don't think people realize how little it adds to the cost. Considering you have to stair at it for the rest of your life!
Scissor trusses and dormers is what I tell everyone building a garage. Makes for a way better space inside IMO
O
overkill 19
Hers the latest work bench and cupboards.
Just added some bolt bins!
The bench just has 3/4"plywood for now. Plan is 1"1/2" butcher block. I will have a rolling metal welding bench and I dont care for metal bench tops... Hard on tools!
xmas bench!! Lol
O
overkill 19
sure like having things put away in own spot vs on a pallet rack
very happy with the quality for the price of the Newage Pro cabinets. Plan is to order 2 more uppers for wall along with bolt bins and 4 full size locker ones for the other side of garage. We have the costco SnapOn pallet racking right now. Which is great stuff but my goal is to have everything put away out of sight.
captain14
I have two questions about your man door installs.
You said outward swinging doors are harder to get into. Why?
And installed flat bag stock behind or in front of the door frame where the stricken slides through? Is is just screwed into/between the framing? That's sounds like a good idea.
Thanks
