I would like to do a few small milling jobs and those anticipated are mostly aluminum motorcycle parts and an occasional small steel part. I have this cross-slide table with rotary motion that seems like it would be large enough for my parts.
I doubt I will be using it to create complete parts but merely to add certain features to existing ones such as straight and curved slots, such as the one in the bracket shown here:
I have two possible options at the moment until I get a real mill, and I would like your recommendations.
Choice #1 - USE DRILL PRESS
A GJ-specific Google search yielded this thread: Drill Press Milling Machine Thread.
It sounds like the consensus was that drill presses shouldn’t be used as a vertical mill. Due to the side loads, quill bearings will not last long and the Morse Taper tends to pop out.
I think I can come up with a way to hold the MT chuck in there. And the fact that I’m mainly working with aluminum and can go slow may increase the life of the bearings. So I think it is still a viable option.
Choice #2 - USE LATHE
I also have an old 12x36 Atlas lathe that could be used. Although these aren’t the best machines out there, it has worked fine over the years for the small stuff I do.
Atlas did sell a milling attachment for it like the one shown below but reviews have been less than stellar on its performance. (This is not mine - just an example)
My thought is that I can make an adapter to mount the cross-slide table onto the carriage when a mill job was needed. It’s just teetering there in the photo to give you an idea where it would go. (BTW, the lathe is just setting on a caster cart in the photo)
So what is your recommendation and why? Thanks in advance.
Sacrilege!
