The garage build site was was started in november 2010 with one big problem, a large boulder on the mound which needed to be removed where the garage is to go. Here are some pictures.
Closed off easier to insulate, storage would be clean, save on flimsy stair cost. Open, easier to put things up thru large opening, things will get dirty or dusty depending on what goes on below.I vote you put sliding barn doors on the attic with a barn door track built into the peak of the building so you can hoist stuff up there. Then build a ladder into the wall on the far side so you can climb up into the loft. Kinda like alot of barns are.
