Doors for rack shelves
abstamaria
Manila
I am planning to install open-rack industrial shelves for long-term storage, but want to put doors to keep things from spilling out (I live in earthquake country) and also to hide the clutter. A great idea, visually appealing to me, is seen in the background of some photos here.
http://www.ferrarichat.com/forum/showthread.php?t=316202&page=5
Any idea how those doors were installed? They seem to be corrugated sheet to me. Would you have other suggestions?
Andy
Stuart in MN
Minneapolis
A
abstamaria
Manila
Thanks, Stuart. I was thinking of the large industrial racks that can be bolted to the walls. I will see if I can lift a photo from the link I posted.
Andy
Voi
Western South Dakota
I'd be interested in seeing those pictures as well.
I've seen pictures of something like this before, I think here on this forum. Pretty sure wood face frames were attached and the sliding glass track was mounted to the frames. Face frames were probably overkill but it cleans up the look, especially if using plywood doors, and it allows the lower track to be mounted lower than the shelves so boxes can be slid over the top of it without contact.
Sliding doors only allow less than half the space to be accessed at once but you don't have to worry about swinging door clearance and the doors are pretty easy to lift out and re-install, assuming you use a deep enough top track.
You can buy the plastic track from Outwater or you can buy aluminum extrusions at steel shops. Or some people mill their own. If you mill your own make sure to make the top track deep enough so you can lift the panels up and out of the track.
A
abstamaria
Manila
Here are the doors.
Here are two photos from the link I posted. I don't have permission to post these so have cropped the owner's photo out. He is a very creative fellow.
I like the look, which is industrial and very modern, especially if they cover a long wall. They are galvanized steel sheets.
I plan to order the industrial racks and bulid similar doors. However, my racks will be much taller, so I will have to alter the design.
Andy
csp
Franktown, CO
That's standard sliding door hardware like used on a barn.
Do a google search on "Sliding barn door hardware" to find suppliers of the track and rollers. Maybe you can find someone who can get it to the Phillipines.
jdub63
Azle, Texas
Here's my racks with sliding doors. Just glue nylon door tracks and 1/4 inch panels for the doors.
icecactus
Wow, i really like the idea of that corrugated roofing as the doors.
I have been thinking about adding doors to my shelves to keep dust out, but i didnt liek the idea of plywood since i have to paint it, plus it likes to warp. This is perfect. Dimensionally stable, cheap and NO PAINT!
A
abstamaria
Manila
Thanks for the suggestions. I will see what the equivalent of barn-door hardware is here, or use another sliding door system.
The owner of the garage twrote me to say they are galvanized sheets that he framed up with 1x4 wood stringers which were also his edges. He used aluminum flat metal bar as a rail with standoffs and bolted wheels onto the panels. As they slide over each other like a closet, one door has wheels on the front and the other on the back. Everything from Home Depot.
Jdub63, your installation is very neat (and you have a very shiny floor!), and I might just go that way. At the moment, I am thinking of large doors covering the whole pallet system, so I can still have the option of moving the shelves around.
Andy
A
abstamaria
Manila
Another Section
Yes, they seem to be barn-door slides. That method is not common here in the tropics, so I will have to adapt another mechanism. The owner has sent me photos and been very helpful, so I will try to do something similar. The concept is so practical and looks great as well (see photo below, drawn from the forum I referred to earlier). He has a great garage.
Andy
tjpavlov
Providence, RI
I know that this is an old thread, but did you ever get around to putting up these doors? I love the idea and would be very interested to hear how it turned out. Also, pictures would be most appreciated!
SWK78
I am interested in & looking for a sliding door solution for 2 sections of 8' x 8' x 30" deep pallet racks.
Has anyone come across a commercial solution, or a vendor in the US that can do something like this?
I would like to incorporate wood & metal, for an industrial theme if possible.
Thanks,
Steve
Storage Guy
New England
If you have existing industrial type closed shelving, most of the manufacturers offer optional doors. They are often available with closed front front or a clear poly glass front. These units are mounted in to a frame that bolts to the upright posts. This only works if you can identify the brand as attaching different manufacturers is more of a hassle than they are worth.
Here is a link to a manufacturer that offer a high quality system that can be modified either with doors, extra shelves, locks or 400# drawers. Remember, not everything belongs exclusively on a shelf or in a drawer, flexibility is the goal.
Available in a multitude of colors at no extra charge.
Manufacturer: http://www.rousseaumetal.com/docs/060-075_Spider_Shelving_System.pdf
Where to buy: Preferred Equipment Resources 800-711-8698
Good Luck
freedomgli
nova
Thanks for the ideas. I'm looking to make some sliding doors to de-clutter my wall of Whalen Black Steel Storage Racks. My problem is mounting the doors in such a way that I still have unhindered access to items on the top shelf as I'm using all the wall space from the floor to the ceiling. I might have to sacrifice and go with a ceiling mounted track as opposed to something mounted on the top shelf.
I was originally looking at the white plastic corrugated roofing as it's cheap but I might have to go for that post modern industrial look and choose the galvanized corrugated roofing tin instead.
I PLAY FOR KEEPS
San Luis Obispo, CA
I have a whalen rack and the same issue with top rack clutter. I'd love to see what you end up doing:thumbup:
sxk122
Dallas, TX
You could possibly make doors work. These are scratch buil with a wood frame and luan skin. For the size I needed the premade doors werent quite right, and this was cheaper.
