homemade funnel holder??
craig1980
NEW YORK
I was wondering if anyone ever made or may have an idea to make a funnel holder. I have about 6 various size funnels for oil, anti freeze, trans fluid, ect. They are all just taking up space on my shelf, and not that easy to get to! Something wall mounted would probally be the best option. Any help would be appreciated.
cheechi
Triad, NC
Take a 2 liter soda bottle, cut off the top. nail that to the wall or attach it to your pegboard etc. Stick the biggest funnel in there and put a rag between each of the others if you want.
Though I do like the idea in the picture there.
Larwyn
Texas
The one I made has adjustable height and will hold a funnel while in use transferring liquids from one container into another, as in emptying drain pan into the empty oil bottles. For storage I just nest the funnels in the holder with whatever drip pan may be handy under it.
Rolling_Thunder
Port Republic MD
Not really funnel holders but here are 2 items Ive made!
232323232%7Ffp63559%3Enu%3D%3B6%3C9%3E%3B6%3A%3E258%3EWSNRCG%3D349%3A364794349nu0mrj
232323232%7Ffp63598%3Enu%3D%3B6%3C9%3E%3B6%3A%3E258%3EWSNRCG%3D349%3A364793349nu0mrj
Honda guy
North Carolina
I use a 5 gallon bucket with a lid. I drilled several holes in the lid, with a holesaw, and just stick the funnels in the holes. The funnels drain into the bucket, and I just throw a rag over the top of each funnel, to keep it clean.
bad_idea
Pasquotank, NC
I opened this thread to see the post count on the OP and to sarcastically suggest the search function be used. But instead I found Larwyn's transfer funnel stand. That is fantastic! I have spilled so much oil transferring oil from the drain pan to jugs. Props go to Rolling_Thunder for your wooden version. But I will definitely be making a copy of Larwyn's stand!
To the OP, there are many threads on this subject. And probably any other topic you can think up. I mean no malice. I have been on this board for a short time now, but have been here long enough to see the same topics keep coming up. That being said, it is good to bring up old topics to see new input on the subject.
RickC
Charlotte NC area
Simple, inexpensive, quick to assemble and does what it's meant to do: Route nasty fluids into a catch jug & give the funnels a place to drip and hang out till needed again.
A quick squirt of brake cleaner into funnel of choice before using again rinses accumulated dust down the pipes. The large red funnel in center is glued in permanently ... the wide diameter and raised back wall make it a good catch basin for most of the things you're looking to pour out somewhere.
RickC
Charlotte NC area
Great idea Rick, any thoughts of having a bigger container to drain into ?
Eric ... the bottom-most white PVC piece, where the clear, braided hose attaches, is 18" above the floor. It'll accommodate a five-gallon bucket with lid. Also, to make it easier to remove the catch container when full, the entire contraption rotates upward in the mounting brackets. The brackets are just common EMT conduit hangers.
customcab
Terra Hote, Indiana
I made this one a while back after seeing sombody elses in a similar thread. It's mounted on a small door that goes to a storage area under my front porch. (my garage is under the house-bi/level) Conduit clamps on mine too. Gotta make one of those grease gun holders!
View media item 21439
Josh Kinzey
Raleigh, NC
Here's mine:
It's made out of rain gutter and some scrap PVC from our pool pump installation. The rain gutter catches any drips that fall off when trying to get the funnel back to the PVC tube that acts as the holder/drain for the funnels.
