concealer404
- Joined
- Mar 13, 2012
- Messages
- 1,147
Let me know how those wrench goes. I have my eye set on the set to 50mm!
Looks like you got some cool stuff there
I hope this thread goes well but ain't holding my breath
Looks good! Those wrenches look a lot like my KT Pro's. Either way should work great.
Looks good stuff, what's the COO?![]()
looks good be sure and keep us updated we want to know what holds up over the long haul day 24/7.
Why'd you get the standard length? They didn't have the long patterns in stock?
How much were the sets of screwdrivers?
I see the screwdriver's look similar to the Witte's, complete with hole in the handle.![]()
Wern't the open end of the wrenches suppoused to have a "flank drive" type feature? Or is that only for the long pattern?
i was surprised I got a Carlyle 1/2" drive ratchet as a napa replacement last week. that is taiwan as well my selector switch broke and they sent me a replacement ratchet instead of just fixing it?
And where is this line available? Napa auto?
How much were those flare nut wrenches? I want a set but can't afford SO. (I heard that SK/Cman/HF were very prone to flexing open).
I have flare line wrenches from snappy, crafty pros(made by sk) crafty rp and gearwrench flex head. I've never ever had any of them flex open.
I've been tempted to get a set of the carlye brand just to test them out
I can't really compare these against any other brands. I've only ever had CM RP flare line wrenches, and those were terrible. Guaranteed to strip whatever i would put them on.
I haven't had experiences with any of the higher-end stuff. I ended up just using vice grips on most stuff after i got pissed at my RPs and threw them away.
Strange you experienced this. I've used mine for more years than I care to remember and never experienced any issues
I'm sure if i tracked down some old ones they'd be just fine. That's probably the issue. Mine were purchased in the last 2-3 years, which also seems to be when the ratchets started being garbage, too.I'm sure if i tracked down some old ones they'd be just fine.
My wife bought me the 9 pc set last Xmas. I got the 16x18mm Allen branded off Cripe to complete. My RP's are very strong. Really excellent value for $35 for the 9 pc set. Used them on a 17 year old NE car on the brake lines and had no issues. I'm completely blown away people are having these issues with them.
I measured the open end and they are made tighter than my SK's.
How much were those combo wrenches?
Retail is $200. Might be cheaper at your local Napa store on the shelf, also depending on what sort of relationship you have with your store, etc...
Do you have a mic? If you do mic the open ends on some. I've noticed on wrenches it's not so much about steel strength (they are all about the same for decent ones) it's about how closely milled the open ends are. The box ends tend to be consistent across brands.
It took me a while to swap my Cman pros and RP's for tight open ends, but it was worth the effort. Strong wrenches and cheap as compared to others.
I typically use it for ballpark work like engine mounts, measuring sway bars, and the like.I do, but it's harbor freight, so who knows how accurate it is.I typically use it for ballpark work like engine mounts, measuring sway bars, and the like.
Thats the one I have too, should be accurate enough for our purposes, I'm just curious how tight they are milled, I find that is one area the higher quality stuff stands out in.
For example someone mic'd the Chinese Craftsman polished ones and they sat at about 0.2mm over (ie a 15mm would measure 15.2mm), which is "reasonable" but IMO too loose. I want to see 0.15mm at most and 0.1mm if possible. Anything over 0.2mm over and it will start to flex open due to the points of the bolt wedging the open end, open.
I dont mean to be an *** or anything like that but i dont get what the big deal is with these tools, from what ive seen so far i think theyre kind of overpriced for imports and dont really see anything special about them, im not saying they are not good tools because i havent tried any of them yet, but maybe im missing something because ive seen a lot of people going crazy about them.
